Solved
Need some advice on psu and case for this build
Last response: in Components
Related ressources
Best solution
Power supply Master
Overclocking Expert
For a system using a single Radeon HD 7950 graphics card AMD specifies a minimum of a 500 Watt or greater power supply. The power supply should also have a combined +12 Volt continuous current rating of 30 Amps or greater and have at least two 6-pin PCI Express supplementary power connectors.
The Antec Neo ECO 520C, with its combined +12 Volt continuous current rating of 40 Amps and with one 6-pin and one (6+2)-pin PCI Express supplementary power connectors, is more than sufficient to power your system configuration with a single Radeon HD 7950. Note: No AC power cord is included with this power supply so you'll have to provide your own.
Antec Neo ECO 520C 520w for 2,200.00 PHP
http://pcx.com.ph/components/power-supplies/antec-neo-e...
