Sound Card: SB Live! 24-bit
Pentium 4 CPU 3.00Ghz
Dell Dimension 4700
Windows XP
Forgive my lack of knowledge if I use any incorrect terminology, but hopefully somebody can help me out. I just installed a Radeon 7750 Graphics Card along with a new power supply. In the past, I believe the PCI Express slot held the old graphics card (X300), the first PCI slot held the sound card, and the second PCI slot held a fax-modem card.
When installing the 7750, I realized it was a larger card that needed extra space, covering the first PCI slot. So I removed the fax-modem card, and moved the sound card down to PCI slot # 2.
I've tried several troubleshooting suggestions, and believe I got the computer to recognize the sound card. I also re-installed the driver (I think). Still no sound though.
In System Information - Hardware - Device Manager, it says:
This device cannot start. (Code 10)
If I go to adjust the volume control, it says: "There are no active mixer devices available. To install mixer devices, go to Control Panel, click Printers and Other Hardware, and then click Add Hardware."
I don't have a "Printers and Other Hardware" button, but when I click Add Hardware it freezes up after a few minutes.
Help?
Dell Dimension 4700
Windows XP
Help?
