Hey, I just want a little feedback on these parts i picked out for my super budget (emphasis on super) build, just wanted to know if these parts will match and keep in mind that i do plan on upgrading these parts in the near future so i chose literaly the bare minimum in parts (tight budget).I already have a CoolerMaster 431 Elite case and a GX series 450W PSU
AMD Phenom II X4 BE
http://www.newegg.com/Product/Product.aspx?Item=N82E16819103727
Kingston HyperX Blu 4GB (2 x 2GB) 240-Pin DDR3 SDRAM DDR3 1333 Desktop Memory Model
http://www.newegg.com/Product/Product.aspx?Item=N82E16820104206
ASRock 760GM-GS3 AM3 AMD 760G Micro ATX AMD Motherboard
http://www.newegg.com/Product/Product.aspx?Item=N82E16813157215
Asus Drive...those are like 20 bucks or so.
SAPPHIRE Radeon HD 6850 1GB 256-bit GDDR5 PCI Express 2.1 x16
http://www.newegg.com/Product/Product.aspx?Item=N82E16814102908
Windows 7
Western Digital Caviar Blue WD5000AAKX 500GB 7200 RPM 16MB Cache SATA 6.0Gb/s 3.5" Internal Hard Drive -Bare Drive
http://www.newegg.com/Product/Product.aspx?Item=N82E16822136769
Now I know that most of these parts are pretty crappy but thats the best I could do right now and I do plan on upgrading my MOBO when I get the cash. So will they be good for now? Thanks in advance.
AMD Phenom II X4 BE
Windows 7
