Solved
First build - Need advice & compatibility check
Last response: in Systems
Just wanted to get some feedback on this build; Would it make a decent rig for gaming, internet surfing/everyday stuff, etc. ? A compatibility check would also be awesome.
I'd greatly appreciate any feedback, thoughts, ideas, opinions.
Thanks in advance
CPU: Intel Core i5-2500 Quad-Core Processor 3.3 GHz 6 MB Cache LGA 1155 - BX80623I52500
http://www.amazon.com/gp/product/B [...] 01_s01_i02
GPU: EVGA GeForce GTX 560 1024 MB GDDR5 PCI Express 2.0 2DVI/Mini-HDMI SLI Ready Graphics Card, 01G-P3-1460-KR
http://www.amazon.com/gp/product/B [...] 01_s01_i01
Motherboard: Boxed Intel Desktop Board Media Series Micro-ATX Form Factor for Second Generation Intel Core Family Processors BOXDH67BLB3
http://www.amazon.com/gp/product/B [...] 00_s00_i01
Hard Drive: Western Digital Caviar Blue 500 GB SATA III 7200 RPM 16 MB Cache Bulk/OEM Desktop Hard Drive - WD5000AAKX
http://www.amazon.com/gp/product/B [...] 01_s01_i05
RAM: Kingston Technology HyperX Blu 8GB 1333MHz DDR3 Non-ECC CL9 DIMM (Kit of 2) KHX1333C9D3B1K2/8G
http://www.amazon.com/gp/product/B [...] 00_s00_i00
DVD Drive: Lite-On LightScribe 24X SATA DVD+/-RW Dual Layer Drive IHAS424-98 - Retail (Black)
http://www.amazon.com/gp/product/B [...] 01_s01_i04
PSU: Corsair Enthusiast TX V2 Series 650-Watt 80 Plus Bronze Certified High Performance Modular Power Supply CP-9020002-NA
http://www.amazon.com/gp/product/B [...] 01_s01_i03
Case: Cooler Master HAF 912 Mid Tower Computer Case (RC-912-KKN1)
http://www.amazon.com/gp/product/B [...] 01_s00_i00
OS: Windows 7 Home Premium SP1 64bit (Full) System Builder DVD 1 Pack
http://www.amazon.com/gp/product/B [...] 01_s01_i06
Best solution
Well first off none of your hyperlinks work. the motheboard is micro atx and the case is atx. The micro atx board will fit in the case but you could get a smaller case and it would be more portable. I would get a 2500k. It is only 10 more dollars and it will allow you to overclock. If you don't think that ability is worth 10 more is your decision. You could easily get ram clocked at 1600mhz for like 5 more bucks or even the same price. You could get a sapphire 6950 for 20 more bucks and it will outperform a 560ti in most games. Those are my recommendations. But id you keep everything the same it will still be a good PC.
Sorry about the links.
I was under the impression that the H67 board I chose wouldn't support overclocking so that's why I didn't put the 2500k in the list.
Thanks for the reply! :)
Related ressources
TheBigTroll said:
what is your budget, location, and parts not required. if you answer, it helps me pick out the right components to put in your rig
$750-850 USD
Southern California, USA
and I need pretty much all the parts that I listed: CPU, GPU, Motherboard, Hard Drive, RAM, DVD Drive, PSU, Case, OS.
Thanks
Ask the community
