Hi my computer is about I built my computer about 3 or so years ago for gaming. I feel like it is getting to hot and I have never noticed it until now. I recently have started gaming again and the computer will just freeze. (no bsod) just have to press the reset button. I ran prime 95 and real temp and my core 0 temp got to 90c in the 10 minute test that real temp runs. So I feel like there is an inadequacy in the ventilation. The computer is cleaned out and there are 3 fans as well as a zalman cpu cooler.
Specs
Intel QuadCore Q9550 2.4gHz
2 EVGA GTX260's
EVGA nforce 780i SLI FTW
8GB DDR2 RAM
800W PSU
Windows 7 64-Bit
Idle Temp: 56c
7 Min Into: Prime95/Realtemp test 90c
I think thats all the specs You need let me know if you need anything else. I understand these temp apps are not accurate but that just seems really high.
Ps. Not Overclocked
Specs
2 EVGA GTX260's
8GB DDR2 RAM
800W PSU
Windows 7 64-Bit
Idle Temp: 56c
Ps. Not Overclocked
