Solved
Removal of power supply Gateway DX4860
Hello, unable to remove power supply from Gateway DX4860. Removed 4 screws but something is still holding it and unable to see what it is. Any ideas?
5 answers Last reply Best Answer
More about removal power supply gateway dx4860
  1. Double face tape, some sort of mechanism inside the case that make it block ... Even if you pull it as hard as you can nothing happens ?
    - The Brownie
  2. Hi --- I am at this very moment trying to do the same thing. :( So far all I see is palecurve here on tomshardware else who had the same problem:
    http://www.tomshardware.com/forum/336473-28-removing-stock-gateway-dx4860-ub33p
    The Gateway instructions (found by Googleing "removing power supply") "point" to a 5th screw but I am having a hard time finding it.
    http://support.gateway.com/support/manlib/cmponts/process/8508750/08750c01.html
    Will let you know if I find anything else!
    Mark
  3. Best answer
    FOUND IT!! :hello:
    Looking down at case lying on its side, there is a metal tab on the right side of the PSU which you simply push down to release....
    Slides right out :D
    Thanks,
  4. marunder said:
    FOUND IT!! :hello:
    Slides right out :D
    Thanks,
    Thank you. I was finally able to get it out using a mini pry bar. I didn't see the tab so I had to do it the hard way.
  5. Best answer selected by backbayfred.
Power Supplies Gateway Components
