I was installing my motherboard last night (Gigabyte GA-Z77-DS3H) into my case (Cooler Master Elite) and ran into some trouble when mounting it with the standoffs and screws. I screwed in the 6 standoffs, put in the IO shield, then aligned my motherboard with everything. I then inserted the screws and began tightening them. 4/6 screws went in fine - the heads rest on the solder star-like shape surrounding the hole. 2 screws, however, would not tighten all the way down to the board. I am nearly certain they are the same type of screw, yet they would not fasten fully. But when trying to remove them, I realized they had become stuck inside the standoff itself and loosing/tightening the screw merely turned the standoff in the case. I tried to prevent the standoff from spinning by squeezing the threaded end protruding on the case's exterior with pliers but even with a full-stength grip, the screw still spins with the standoff.
What should I do?
-Try and use a vice-grip to stop the standoff from spinning? (The threads on the standoff are already damaged from the pliers.)
-Or simply turn it so the standoff is in fully and ignore the 2 screws that aren't touching the motherboard? (is this a danger to the board?)
I cannot remove the motherboard as is, but do not need to. Seeing as the board is secured and elevated off the case panel, is there really anything problematic beyond the board being stuck?
Thank you very much!
-Neil
What should I do?
-Neil
