Power supply
  • Power Supplies
  • Dell Inspiron
  • Components
  • Product
Last response: in Components
January 1, 2013 10:05:42 AM
my power supply of my dell inspiron 530 failed and I changed fora new one, after working fine for 2 weeks the new ps failed; any ideas what is causing this? thanks
More about : power supply
a c 723 ) Power supply
January 1, 2013 1:35:50 PM
Hard to say might be a short in your system or just that you got a bad one that just vent by itself. What was the replacement PSU?
m
l
January 1, 2013 2:20:49 PM
Hi
It was shark technology
Connector Summary
1x 24pin Main Power Connector,
1x P4 4pin Power Connector,
1x Floppy Drive Power Connector.
3x SATA Power Connectors (on 2 seperate line of cables to reach drives located in various part of the case)
4x Peripheral Power Connectors for IDE drives or case fans.
Complies with INTEL® ATX 12V standard
Super Silence Technology provides best solution for fan noise and heat
High efficiency output
One 12VDC 120mm low-RPM fan
Output short circuit protection (except +5VSB)
Output over voltage protection
Output over wattage protection (620W)
Manual power shut down rocker switch
I am just wondering if the motherboard has diabled the new power supply?
Many thanks
m
l
January 1, 2013 2:26:01 PM
That's a very generic brand of PSU's.
m
l
January 1, 2013 2:31:28 PM
iramesor said:
Hi
Connector Summary
Many thanks
Can be but it is a low quality PSU that could have died by itself. Quality PSU's have internal protection so they will not turn on for example if there is a motherboard short.
m
l
January 1, 2013 2:32:47 PM
true. have you got any suggestions for psu?
Many thanks
m
l
January 1, 2013 2:34:04 PM
You shopping online or store?
m
l
January 1, 2013 2:34:27 PM
any suggestions for better psu?
many thanks
m
l
January 1, 2013 2:35:21 PM
shopping online
thanks
m
l
January 1, 2013 2:36:44 PM
Corsair, Antec, Enermax, Seasonic, PC Power and Cooling are all few of the well known quality brands.
m
l
