Closed Solved
Best fan speed controller
I've been looking at various fan speed controllers and was wondering if anyone could recommend one? Also any other suggestions to fill my drive bays? Thanks
5 answers Last reply Best Answer
More about best speed controller
  1. Best answer
    i use this one
    can change the leds to different colours to suit the case
    50w a channel so capable of daisy chaining a huge amount of fans if needed
    no rpm or temperature display
    http://www.scan.co.uk/products/nzxt-sentry-mix-led-illuminated-fan-crontroller-with-six-50w-channels-5-led-colours-slider-controls
  2. That one looks good, can it change the colour of any led fan? I've also seen the NZXT sentry 2 which gives temps and its touch screen.
  3. it doesnt change the colour of the fan led--the fan would need colour changing leds to do that
    the colour of the numbers 1 to 6 on the fan controller change
    its got a rubberised front so goes great with my storm trooper case
    heres a link to a review
    http://www.youtube.com/watch?v=O0qhiVyHx0Y
  4. Oh okay. Thanks for the reply
  5. Best answer selected by m_lowe.
Controller Fan Speed Components
