Archived from groups: rec.photo.digital (More info?)
Big problem! I'm using Canon EOS20D and have a Sandisk Extreme II 1 gig
containing a bunch of RAW images. My card reader ignores the card when I
plug it in. When I connect the camera directly to my PC - the windows camera
and scanner wizard opens and shows "no images" I can see them on my
camera's display. I took another card and had the same results. I then shot
a JPEG image. This one does appear, but not the RAW images. Any ideas?
"Geoffrey Ungar" <dejugs@hotmail.com> wrote in message
news:cj%Se.10169$p5.7200@nnrp.ca.mci.com!nnrp1.uunet.ca...
> camera and scanner wizard opens and shows "no images" I can see them on
> my camera's display. I took another card and had the same results. I then
> shot a JPEG image. This one does appear, but not the RAW images. Any
> ideas?
doesn't a comp, Windows, have to have specific RAW reading software before
it will recognise a RAW file on a hard drive or your case a mass storage
device.
I have numerous programs that recognize RAW files and have downloaded many
in the past.
"Glittery Gary" <OnThe@Upbtinternet.com> wrote in message
newsfi0q2$1bb$1@nwrdmz02.dmz.ncs.ea.ibs-infra.bt.com...
>> then shot a JPEG image. This one does appear, but not the RAW images. Any
>> ideas?
> before it will recognise a RAW file on a hard drive or your case a mass
> storage device.
news:jG%Se.10170$p5.3494@nnrp.ca.mci.com!nnrp1.uunet.ca...
>in the past.
>>> Any ideas?
>> storage device.
>in the past.
>>> Any ideas?
>> storage device.
or read for yourself............have you heard of Google.............then
bloody well use it.
The Windows camera wizard WON'T show you RAW files on EOS cameras..
The Microsoft camera wizard is only programed to shows JPEGS .
I don't understand why your card reader 'ignores' the cards.. It could be
a bunch of things.. Perhaps the reader has gone bad ? Check your USB drivers.
If you load the software that came with the camera (zoombrowser etc), you
will be able to download your RAW files..
Camera is set to normal - as it always has
newsfi2k7$7qu$1@nwrdmz03.dmz.ncs.ea.ibs-infra.bt.com...
>>in the past.
>>>> gig containing a bunch of RAW images. My card reader ignores the card
>>>> when I plug it in. When I connect the camera directly to my PC - the
>>>> windows camera and scanner wizard opens and shows "no images" I can
>>>> see them on my camera's display. I took another card and had the same
>>>> results. I then shot a JPEG image. This one does appear, but not the
>>> storage device.
> is camera still set to PTP...........
I've already gone Google - what exactly is your problem - have you gone
schitzo?
newsfi2na$82i$1@nwrdmz03.dmz.ncs.ea.ibs-infra.bt.com...
>>in the past.
>>> storage device.
> bloody well use it.
I've tried a few programs ie: ACDSee... and nothing. The strange thing is
that I can view them in my camera. The windows file manager shows the
directories on the card but not the files...
"Jim Townsend" <not@real.address> wrote in message
news:11hp3nur9004kd8@news.supernews.com...
>> camera
> drivers.
>> shot
then use it...........
news:N91Te.10175$p5.4949@nnrp.ca.mci.com!nnrp1.uunet.ca...
> schitzo?
>>>many in the past.
>>>> storage device.
>> bloody well use it.
Doesn't sound like a big problem, just don't use the Windows Camera and
Scanner Wizard. When you insert the card, choose the last option to open a
folder to view files. You should see img_XXXX.cr2, etc. Then cut/copy,
drag/drop, whatever to get them to your hard drive.
Beyond that you will need some sort of RAW viewer as suggested in other
posts, or just use the Canon software.
HTH
bh
> ideas?
The card reader won't ignore it. It also won't read it. It just makes
it available to some app to read it. If the card reader is bad, it
won't even do that.
What software are you using to access the RAW files? Windows Explorer
should see the files. It won't display them, but it should see them.
Does it?
We need more information than you've given.
Tell us exactly what you're doing, what programs you're using.
Bill Funk
Replace "g" with "a"
funktionality.blogspot.com
The problem is that Windows camera wizard and ACDSee aren't
designed to get RAW files off a USB connection to a Canon
camera.
This is normal..
Either get your card reader working, OR install the software that
came with your camera.. Canon wisely included software that allows
you to download RAW files directly from your camera.
>>> camera
>> drivers.
>>> shot
1) When I plug the card into my computer's built-in card reader - nothing
happens. It used to automatilcally open a dialogue box asking me what
actions I chose to take.
2) If I plug the camera into a USB port, a dialogue box opens asking me to
select a program to launch an action. I have numerous programs offered to
choose from including camera wizard, Photoshop, ACDSee. None of them come up
with any image files.
3) If I open Windows Explorer (with my camera still plugged in) I can acess
my camera and see the directories on my card. However the directories do not
display (list) any files inside. I know they are there because they can be
viewed in the camera.
"Bill Funk" <BigBill@pipping.com.com> wrote in message
newsfaph1tdnj6fehnhk1dr4359vgdp032cu8@4ax.com...
> On Mon, 5 Sep 2005 13:32:56 -0400, "Geoffrey Ungar"
>>camera
>>shot
> won't even do that.
> Does it?
> Bill Funk
Unplug your card reader.
In Device Manager delete all USB devices.
Reboot PC.- are USB controllers reinstalled?
Plug in card reader - is it detected?
Plug in memory card - see the files? if not then try another card reader...
Copy files to hard drive...
Guy
> nothing happens. It used to automatilcally open a dialogue box asking
> me what actions I chose to take.
> me to select a program to launch an action. I have numerous programs
> offered to choose from including camera wizard, Photoshop, ACDSee.
> None of them come up with any image files.
> acess my camera and see the directories on my card. However the
> directories do not display (list) any files inside. I know they are
> there because they can be viewed in the camera.
>>> 1 gig containing a bunch of RAW images. My card reader ignores the
>>> card when I plug it in. When I connect the camera directly to my PC
>>> then shot
>>> ideas?
>> won't even do that.
>> Does it?
>> Bill Funk
Bigguy has an excellent sugestion.
Do other cards get read by that reader? If not, the USB port it's on
may be faqrkled. Do what Biguy sugests, and see if that helps. If not,
the problem will be different (obviously) but it tells us to look
deeper.
Bill Funk
Download Pixmantec Raw Shooter while it is still FOC,, promises to be a good
program
Borge
Start/run/regedit
select HKEY_LOCAL_MACHINE
navigate to system/services/atapi/parameters or
system/currentcontrolset/services/atapi/parameters
right click for new
Select Dword name it EnableBigLba (take note of case)
set value to 1
end regedit
reboot
The card reader shouldn't care what the file format is. It should allow you to copy any
file on your card to your hard drive. If it works on and off, it may be because the
contacts on your card or in the reader need to be cleaned. The low-voltage connections
are easily disrupted by even a little dirt.
