I've been lurking around here because I really am wanting a computer built to my configurations. (However, buying $800 worth of parts and then messing something up and not being able to get help? I'd rather pay a little extra.)
I plan on using this machine for gaming and video editing.
What are your thoughts on this build? I know a lot of people are going to tell me that I can get cheaper if I build my own, but I can't afford to screw it up. And knowing how clumsy I am, I will screw it up.
AMD FX-4100 Quad-Core 3.6Ghz 8MB Cache AM3+
AMD Heatsink and Fan Included
ASUS M5A78L-M LX Plus (Radeon HD3000 Video, HDMI, 6xSATA, 2xDDR3)
8GB (4GBx2) PC3 10666 DDR3 1333Mhz Memory Lifetime Warranty
1TB 7200RPM 32MB Cache SATA3 6Gbps (Major Brand)
24X LG SATA Dual Layer DVD /-RW/CDRW w/Nero
1GB GeForce GTX 560Ti GDDR5 PCI-E Dual-DVI/HDMI (Major Brand)
Microsoft Windows 7 Home Premium 64bit
Thermaltake V3 Black Edition (4 5.25, 5 3.5) Fan, Audio/USB
500watt Cooler Master Extreme Power Plus
Onboard LAN included
Onboard Sound included
2x 120mm Case Fan
Wires and Cables neatly tied up away from fans
3 Year Parts and Labor Warranty
This comes to around $800 with the 5% coupon.
Thanks!
(If you have suggestions of other prebuilds with the same power or greater that are in the same price point I'd love to hear them. The only thing I'm really determined on is getting that 560 ti. It seems to get the best bang for the buck. (I wouldn't be opposed to two 550 tis if there is a site where that is cheaper.) I'm just hesitant to get a Radeon because I've heard there have been glitches with modern games.)
Also, has anybody used ecollegepc? Are they good? I've read good reviews about them and they have great reviews on ebay, but it'd be nice to hear if anybody else has used them.
2x 120mm Case Fan
Thanks!
