I built my PC by myself just about a year ago. It was my 3rd build and went relatively smoothly. Pretty high end parts and no issues since I built it.
About 5 days ago, I started having 3 separate problems....
1) The first problem is that my main monitor (an ASUS 27 incher that is a couple of years old) won't wake up if it goes to sleep. It also doesn't start up on boot until I get to the windows log-in screen. My secondary monitor will boot up (so i can use it to see the bios menu) but not the main one.
2) The 2nd issue is that it appears that my PC isn't recognizing 2 of my 3 hard drives until I actually log into windows. I have an SSD (which holds windows and a couple of games) and two 800 GB regular hard drives for data. One of the regular HD's is recognized at boot (and in the BIOS) but it doesn't appear that the other 2 are. Once I log into windows, I hear 2 "beeps" indicating that the system has recognized 2 new pieces of hardware (presumably the SSD and the other HD) and then they work fine after that. I can access anything I want off of any drive and even play games for hours without a problem (unless the 3rd problem happens).
3) My computer has basically crashed a handful of times. It has usually happened while web browsing, but happened once during gaming as well. Basically, whatever I'm doing on the screen freezes for like 20 seconds, and then I get a picture of my desktop (but with no icons) and then the screen goes black.
Considering whatever is going on appears to be affecting my SSD, one HD, maybe my vid card and my monitor, I have to presume its a motherboard issue, right?
FWIW, when I try a re-start, I get a black screen during boot with the message "Reboot and Select Proper Media device or Insert boot media in selected boot device and press a key_". The only way to get past this screen is to actually turn off the computer manually (at which point I get the message that tells me windows was shut down incorrectly the option to boot from safe mode.
I can't imagine this is any sort of virus or anything like that. I haven't installed any new programs and I tried a system restore to go back a week or so, but that didn't help. Any advice would be greatly appreciated. Full specs below....
Case: Coolermaster HAF 32 full tower
Power supply: Coolermaster Enthusiast series 750 Watt
Motherboard: ASROCK P67 Extreme 4
Processor: Intel i5 2500K sandy bridge
Vid card: NVIDIA 570 GTX
RAM- 16 Gigs GSkill rip jaws X series (4 x 4 gigs)
SSD (boot drive)- 128 Gig Crucial M4
HD X 2- 800 GB western digital caviar black
