Closed Solved
Catalyst 12.6 Overscan setting restart issue.
Hello,
I just installed catalyst 12.6 from 12.4, used the custom install and had everything selected. When restarting my computer, the underscan appears to be set to 10%, but in CCC, it reports it as 0. In order to bring it back to normal (no black bars), I have to move the slider to another spot and back and it fixes the issue. Restarting it again it back, even though CCC says it was 0.
I have a sapphire radeon 7850 and windows 7 64bit, which didn't have this issue before (with both 12.3 and 12.4). Can anybody help me with this issue? I'd like to not have to manually set the slider every time I restart the computer, and would like to know if this is a symptom of any other 12.6 or graphics card issues. If the problem persists and I don't notice any performance benefits from 12.6 I might just roll back to 12.4 until another update is rolled out.
Thanks,
brewspy
What I have done/tried:
I have a Asus 1920x1080 monitor, a hdmi cable from the gpu to the monitor (tried replugging), checked window's settings for resolution/refresh rate/color are all unchanged. The monitor's menu settings are set correctly (at least the easily accessible ones are). I've only used the 64 bit vers for windows 7, and always got the updates from the AMD website. I went into CCC and used the detect monitor button (nothing appeared to change), and the default setting button in the overscan submenu, restarted, set it back, restarted again - issue persisted.
19 answers Last reply Best Answer
More about catalyst overscan setting restart issue
  1. brewspy said:
    Hello,
    Thanks,
    brewspy
    Having the exact same issue and have been troubleshooting it for a while now. I actually tricked the system by sticking a DVI to HDMI adapter from the video card to the HDMI port on the monitor. This fixed the issue, however it created audio issues with crackling, etc. Then, get this....magically, after I installed 12.7 BETA, it started to treat the DVI-HDMI just like HDMI, and the scaling (underscan issue) resurfaced.
    Pretty ridiculous that they haven't addressed this issue yet. I'm tempted to go back to 12.4 too.
    Thanks for the reply. What other things have you tried doing? Have you asked AMD about this? I'm tempted to.
  3. I just submitted a report about this issue to AMD. I'll let you know when I receive a response from them.
  4. A clean install after uninstalling all AMD Catalyst software and then using driver sweeper solved the problem for me. Hope this helps!
  5. Theres a simple solution: a good quality DVI - HDMI cable. For me it worked. No over scan issues on reboot! I have 2 HD 5050 in crossfire and I can play Crysis 2 on 24'' Monitor 1080p, everything ultra, Direct x 11, HD pack, and I get 60 FPS whit VSync on.
    Regards.
  6. * sorry: HD 5850 x2 crossfire
  7. Hm. Neither a clean install using driver sweeper nor using a DVI-HDMI cable works for me.
  8. Actually, I just noticed an odd thing... the underscan pops back to normal when you make *any* change in the CCC, not just playing with the underscan slider.
    Methinks someone flubbed something with their software during the most recent update. We may just need to wait until they fix it.
    Regards.
    The cable shouldn't be the issue. Trying different mixtures of cables didn't work (Just HDMI, just DVI, converters between the two). Plus, I think the quality of the cable shouldn't matter for this sort of issue when no other problems are detected.
    That's what I just tried. Didn't work either. I also noticed that changing any setting would put the overscan back to normal.
    Still no response from AMD, but I doubt I'll have one until later this week as I submitted the ticket on Friday.
  10. Sorry I was a little hasty in thinking the problem was solved with a clean install, it is indeed resetting with each restart now, apologies.
  11. Best answer
    I found a fix for the overscan issue
    Go to the following key in the registry:
    HKEY_LOCAL_MACHINE\SYSTEM\CurrentControlSet\Contro l\video{####....}\0000
    Create a new DWORD:
    "DigitalHDTVDefaultUnderscan" = dword 0x0000
    Note: there might be several {####....} , should be the one with most of the ATI settings.
    Source:http://forum.beyond3d.com/showthread.php?t=62100
    I'm just reporting my experience, nothing else. With me, after using a cable DVI/HDMI the problem was solved. After booting no more over scan issues. About cable quality, I prefer always the best cables. Regards.
    Create a new DWORD:
    This worked for me, many thanks.
  14. Best answer selected by brewspy.
    Create a new DWORD:
    Hey thanks so much! That seems to have fixed the overscan issue. I had a feeling it had to do with the registry.
  16. this helped me too! thank you very much :)
    You know when somebody comes up and says "I always use best quality cables and I don't have your problem", it suggests that the person with the problem is a cheapskate and while spending lots of money on cards, he is pennypinching on cables. It never was the cable, it's fixed with changing the registry :)
  17. Yep, that sorted it. Thanks, razer_76!
  18. yes thank you razer_76.
    and may i say i'm pretty pissed at AMD? again and again they don't fail to disappoint :)
  19. This topic has been closed by Mousemonkey
Radeon Catalyst Graphics
