Monitor display stuttering/flickering !!!
i tried putting in a pci card with the system on, i got a message
"network cable unplugged" and after that i was not able to fix that
network port no matter what(integrated with motherboard)
i put in a pci to lan card and am using it now and is working
properly.....
but now the problem is my display. the screen stutters when i try to
play videos and my cpu performane is way higher than before
these thing i already tried 1)re install driver, update driver 2) re
install OS 3)change frame rate 4)try different hard disk
stuttering started right after the ethernet port had problem
