Hello,
Due to my being further up in Canada, I can generally only buy from Canadian websites. I don't really want to pay brokerage/customs, etc. Amazon.ca, Tigerdirect.ca, and Newegg.ca are the ones I've come across so far. The parts in the US would cost around 1200. Here around 1600. And although I'm not happy about that, I'll just set my budget at around 1600 and get this headache over with.
Here are the specs so far:
Motherboard:
GIGABYTE GA-Z77X-UD3H Intel 7 Series Motherboard - ATX, Socket H2 (LGA1155), Intel Z77 Express, 1600MHz DDR3, SATA III (6Gb/s), RAID, 8-Ch Audio, Gigabit LAN, USB 3.0, PCIe 3.0, CrossFireX/SLI
http://www.tigerdirect.ca/applications/SearchTools/item-details.asp?EdpNo=2276156
The GPU:
GIGABYTE GeForce GTX 670 2GB Video Card and NVIDIA GeForce Game Coupon: Borderlands 2 Bundle
http://www.tigerdirect.ca/applications/searchtools/item-details.asp?EdpNo=3734599&csid=_22
Figured I might want dual 670 SLI down, down the road. Also comes with Borderlands 2.
The Core:
Intel Core i7-3770K BX80667i73770K Processor - Quad Core, 8MB L3 Cache, 3.50GHz (3.90GHz Max Turbo), Socket H2 (LGA1155), 77W, Fan, Unlocked, Retail
http://www.tigerdirect.ca/applications/SearchTools/item-details.asp?EdpNo=2372989&CatId=1969
The PSU:
Corsair CMPSU-750AX Professional Series Gold High Performance 750-Watt Power Supply
http://www.amazon.ca/gp/product/B003PJ6QWE/ref=ox_sc_act_title_4?ie=UTF8&smid=A3DWYIK6Y9EEQB
The... Internal Bare Drive?:
Seagate Barracuda 7200 1 TB 7200RPM SATA 6 Gb/s NCQ 64MB Cache 3.5-Inch Internal Bare Drive ST1000DM003
http://www.amazon.ca/gp/product/B005T3GRNW/ref=ox_sc_act_title_3?ie=UTF8&smid=A3DWYIK6Y9EEQB
LG DVD:
Super Multi DVD R/W 24x Sata Nonlight No Acc Inc
http://www.amazon.ca/gp/product/B00632SB2I/ref=ox_sc_act_title_2?ie=UTF8&smid=A3DWYIK6Y9EEQB
SSD:
Samsung 830 Series MZ-7PC128B/WW 128GB Internal Solid State Drive - 2.5" Form Factor, SATA III 6Gb/s, Up to 320MB/s Write and 520 MB/s Read
http://www.tigerdirect.ca/applications/SearchTools/item-details.asp?EdpNo=2318704&CatId=5300
The Cooler:
Cooler Master RR-B10-212P-GP Hyper 212 Plus CPU Cooler - 120mm, LGA 1366, 1156, 775, AMD AM3, AM2+, AM2
http://www.tigerdirect.ca/applications/SearchTools/item-details.asp?EdpNo=4950641&CatId=798
Memory Kit:
Patriot Viper 3 Intel Extreme Masters PVI38G160C9K 8GB Limited Edition Memory Kit - 2 x 4GB, PC3-12800, 1600MHz, 9-9-9-24, 1.5V
http://www.tigerdirect.ca/applications/SearchTools/item-details.asp?EdpNo=3468751
- Firstly, can someone tell me how to check for compatibility? What are the parts I should be concerned fit together, so to speak?
- I have the 750w PSU Gold up there for around 169. There is an 850w PSU Gold coming out in like 3 days... http://www.pccasegear.com/index.php?main_page=product_info&cPath=15_305&products_id=17425 ... for the same price, and I'm wondering if I should just order that instead. Can't have enough watts, can you?
- If anything stands out to you, please lemme know. I really want to make sure it's all compatible and that all parts listed are all that is necessary to build the computer.
- Is that cooler sufficient-enough? At first I was going to get the 212, but... (US: 30, CA: 60-120)... I think this one may be better anyway.
Well, that's that; hopefully I can order by the end of the weekend. Any suggested parts, online guides, etc, are very appreciated!
Thank you,
Motherboard:
The GPU:
The Core:
The PSU:
LG DVD:
SSD:
The Cooler:
Memory Kit:
Thank you,
