Will everything work properly and do you have any suggestions to lower the price? (Need to keep the build as cheap as possible, under $1000)
I'll be using the Intel Core i5's integrated graphics for awhile.
(EDITED)
1. CPU: Intel Core i5-3570 - http://www.newegg.ca/Product/Product.aspx?Item=N82E16819115233
2. Motherboard: Gigabyte G1. Sniper M3 - http://www.newegg.ca/Product/Product.aspx?Item=N82E16813128551CVF
3. RAM: Mushkin Enhanced Blackline 8GB - http://www.newegg.ca/Product/Product.aspx?Item=N82E16820226191
4. PSU: Corsair HX850 850W Power Supply - http://www.newegg.ca/Product/Product.aspx?Item=N82E16817139011
5. HDD: Western Digital Blue 500GB - http://www.newegg.ca/Product/Product.aspx?Item=N82E16822136769
6. Case: Corsair Carbide 400R - http://www.newegg.ca/Product/Product.aspx?Item=N82E16811139008
7. OS: Windows Home 7 64-bit - http://www.newegg.ca/Product/Product.aspx?Item=N82E16832116986
8. Arctic Silver Thermal Compound - http://www.newegg.ca/Product/Product.aspx?Item=N82E16835186038
9. Cooler Master Hyper 212 Evo - http://www.newegg.ca/Product/Product.aspx?Item=N82E16835103099
(EDITED) I will later be buying a GTX 670 GPU when I can afford it, I will not be running in SLI and I will not be overclocking anything.
(EDITED)
