Which Power Supply is better ? Tags: Power Supplies Graphics Cards Components Last response: January 2, 2013 7:11 PM in Components Share gazum123 January 2, 2013 2:03:56 PM Hello, I am upgrading my power supply to support a new Graphics card that I will be ordering. These are my specs: Bulldozer FX 6100 Nvidia Geforce 9600GT Alpine 700w Power Supply Kingston Something ram 1600 16gb 120 OCZ SSD 500gb Seagate Barracudia I was looking at a new power supply as I need to update my graphics : Here are the two I have seen http://www.pcworld.co.uk/gbuk/ocz-zs650w-uk-zs-series-a... http://www.pcworld.co.uk/gbuk/corsair-builder-series-cx... Which one would you recommend ? Cheers Gazum More about : power supply Kamen_BG a b ) Power supply a b U Graphics card January 2, 2013 2:15:30 PM The OCZ one is a very good deal. Go for it. groundrat a b U Graphics card January 2, 2013 3:48:09 PM I havent had good luck with OCZ. Its a good deal for a reason. The Corsair will last longer and give you cleaner power. Can't find your answer ? Ask ! Get the answer toyftw a c 311 ) Power supply a c 119 U Graphics card January 2, 2013 7:11:07 PM gazum123 said:Hello, I am upgrading my power supply to support a new Graphics card that I will be ordering. These are my specs: Bulldozer FX 6100 Nvidia Geforce 9600GT Alpine 700w Power Supply Kingston Something ram 1600 16gb 120 OCZ SSD 500gb Seagate Barracudia I was looking at a new power supply as I need to update my graphics : Here are the two I have seen http://www.pcworld.co.uk/gbuk/ocz-zs650w-uk-zs-series-a... http://www.pcworld.co.uk/gbuk/corsair-builder-series-cx... Which one would you recommend ? Cheers Gazum Hi -I'd go with OCZ in this instance, as it has good reviews form from a couple of reputable sites. See below (courtesy of johnnylucky.org): OCZ-ZS650W ATX12V & EPS12V 650 1 x 46 Amps Bronze Sirtec Hardware Secrets, TechPowerUp Tom Can't find your answer ? Ask ! Publish Read discussions in other Components categories Power supplies Sound cards NICs Akasa Antec Cooler Master Cougar DeepCool Enermax !
