Hello. After deciding to wait for ddr4 before building a new desktop pc, i decided to make a HTPC for multimedia, streaming, youtube, internet and similar.
The HTPC will be connected to a Samsung UE40D5000 TV and Genius sp-2020 speakers which have both a analog and digital input. I will be connecting htpc to the tv via HDMI. The connection to the speakers worries me a bit. I want to connect the htpc to my speakers via coaxial digital audio cable for digital sound. So i will need a coaxial audio output on my HTPC. What do i need to buy to make this happen? Can i and should i get a sound card or is there no need for these speakers?
Since my budget is tight i don't have much options when it comes to cases. I decided on a LC-Power 2049MB. It is only ~50$ and comes with a 300W lc-power PSU. Here is the link: http://www.lc-power.de/index.php?id=334
I decided to get a intel 1155 sata3/usb3 Motherboard which has to be matx or mitx. Which motherboard do you recommend(50-70$)?
Which sata3 HDD is the quietest and reliable(500gb-1tb)?
The only thing im pretty sure is that i will be getting a intel g550 and a Asus GT 610 gpu. I think that it is the better option than the Apu a6-3650, what do you think?
