Computer doesnt start with PCI-E 6pin or 8pin power connector
Last response: in Components
- 8pin to 6pin pcie power connector Forum
- Split 8-pin PCIe connector to two 6-pin PCIe connectors Forum
- SolvedEVGA Gtx 770 - Question on 6-pin and 8-pin PCI-e connectors Forum
- Does a 8-pin PCI-E connector fit in a 6-pin? Forum
- Is 6pin to 8pin power connector going to work? Forum
- Box says tht i need 2 6Pin PCIe connectors but the card has a 6PIN and 8pin port??? Forum
- Nvidia geforce gtx 295 6-pin and an 8-pin pci express auxiliary power connector Forum
- SolvedPCI-E 8-pin power connector? Forum
- Antec CP-850 - No power from 8pin to 6pin PCI-E cables Forum
- SolvedWhere to find PCI-e 6-pin connector TO power supply? Forum
- SolvedIntel DG41RQ has 6-pin PCIE power connector ?? Forum
- Solvedjump starting a power supply 8-pin connector plugged in? water cooling Forum
- 8-pin CPU connector from power supply seemingly doesn't match with corresponding 8-pin connector on motherboard Forum
- SolvedHelp, GTX 770, Do I use the 6 and 8-pin power connectors on my PSU labled PCI-E or do I use the adaptors? Forum
- 8pin PCI-e powered cards and old power suplys with only 2 6-pins, any solution? Forum
- SolvedCan I Convert Two 4pin Molex Connectors to 6pin PCIe to power AMD HD7870 Forum
- New ATI Card and 6-pin PCI-e power connector Forum
- SolvedComputer doesn't start when I hit power, but it's receiving power! Forum
- Bad power connector on Radeon 7950 causes computer to die immediately on start Forum
- More resources
Read discussions in other Components categories
