Hi There,
My homebuilt system that I made in Sept 2011 has recently been playing up...it's now become unusable due to freezing, occasionally not booting up and most of all stuttering.
It has also for a few weeks been unsafely shutting down and rebooting on it's own.
The first thing I notice if the machine boots up is that when moving the mouse around it is stutters. If i play music through spotify, you'll occasionally hear a stutter in that too which sounds like a digital artifact noise.
The strange thing is that occasionally I can use the computer fine for a while...maybe an hr, even playing new games like Sleeping Dogs really smoothly...until the stuttering starts and effects the game with the brief pauses.
I should mention that i tend to leave my computer on for long periods of time... a habit from work where we don't power down our machines at all.
Another thing that i have done relatively recently is re-install windows and freshen up my computer. I don't know if it's co-incidence that the problems happened after this event.
My exact specs are:
-Corsair 8GB (2x4GB) DDR3 1600MHz Vengeance Memory Kit CL9 1.5V
-Intel Core i7 2600k 3.4GHz Socket 1155 8MB Cache Retail Boxed Processor
-Asus P8P67 Pro R3 P67 Socket 1155 8 Channel HD Audio ATX Motherboard
-KFA2 GTX 560Ti OC 1GB GDDR5 Dual DVI HDMI Out PCI-E Graphics Card
-Seagate 1TB 3.5" Barracuda SATA-III 6Gb/s Hard Drive - 7200RPM 32MB Cache
-Coolermaster CM690 II Lite with Coolermaster GX 650W PSU *Special Offer Bundle*
-Arctic Cooling Freezer 7 Pro rev 2 Socket 775, 1156, 1155, 1366, AM2, AM3 Heatpipe CPU Cooler
I've tried several things trying to get to the root of the problem.
Most recently I thought it could be bad RAM. So i did a memtest. When I did the first test with both sticks of RAM in there in the 2 & 4 slot...after about 2hrs i got loads of faults and err's.
So I took one stick out and tested again. This test was fine for the length of time i ran the test for...only 3hrs again.
I then put only the other stick of RAM in(in it's original slot) and tested it. I got the err's again.
I thought it could be the slot that was the problem so put what seemed to be bad RAM in the other slot i knew was fine...again i got err's.
So I deduced that that stick of 4gb corsair RAM was bad. I was really pleased as I thought i'd solved it! But when I booted up the computer with the one stick of 'good' RAM the stuttering problem persisted.
I'm now at a bit of a loss... it's a bit strange as if it wasn't the RAM, was it co-incidence that the RAM is bad? hmmmnnn...
What else could it be...I know it could be a multitude of things, but that's the problem, what is my next port of call?!
Would really appreciate the help. My comp used to be so good and smooth...running everything from my editing progs to high end games....now i can't do anything on it! eeeek.
I don't mind replacing parts and stuff...just need to know what to replace!
Thanks in advance for any response!
My exact specs are:
