Tom's Hardware > Forum > Mobility Brands > Nokia > Nokia 6600 PC Suite problems with BT
Forum Mobility Brands : Nokia - Nokia 6600 PC Suite problems with BT
Archived from groups: alt.cellular.nokia (More info?)
Recently I've bought a new Nokia 6600 and tried to connect it to my
PC with the BT Dongle I already have frok Mobiltek.Problems began at
this point and tired of figting with PC Suite of Nokia.So need some
help from you.
I'm using Win XP Pro Version 2002 SP 2 ( Build 2600 ) at my PC with
Bluetooth USB Dongle from Mobiltek.As mentioned at Nokia 3650, 6600
and N-Gage Bluetooth Cell Phone.pdf from windigo systems(
www.windigosys.com ) first I installed PC Suite for Nokia 6600 version
1.1.0 and then the XTNDConnect Blue Manager 3.1b.Here are my Device
Manager settings:
Bluetooth Bridge Bluetooth COM Bridge Manufacturer Windigo systems
btkrnbdg.sys File version 2,0,0,0 Device Instance Id
Root\Bluetooth_Bridge\0000 Hardware Ids ESI0108
COM Ports BT COM port - DUN COM31 Btcomm.sys File version 1,0,0,0
COM Ports BT COM port - FAX COM33 Btcomm.sys File version 1,0,0,0
COM Ports BT COM port - LAN COM32 Btcomm.sys File version 1,0,0,0
COM Ports BT COM port - SERIAL COM30 Btcomm.sys File version 1,0,0,0
As mentioned at Nokia 3650, 6600 and N-Gage Bluetooth Cell Phone.pdf
• Please install PC Suite for your Nokia phones;( done )
• After Installation, there will have two icons in the system tray
(done )
• Install Blue Manager, end user can download this version from
www.windigosys.com/support.htm and please remember to install the
version for Other only; ( done )
• After installation and rebooting system, please run Blue Manager,
make sure that your Nokia phones are in discoverable mode, we use
Nokia 3650 as example here. In Blue Manager, right click icon of Nokia
3650, select ‘Trust Device' to pair computer with phone; ( done for
6600 )
• Please check the Bluetooth virtual serial COM port, in Blue Manager,
Tools,Options,Bluetooth Ports, please remember the port number;( Done
• Double click the left icon in the system tray to open one dialog
window named ‘Connection Properties' to select right port to connect
to, ( Done )
• After selecting the right port there will have a jump out dialog,
please select right phone; ( Done )
• Double click the application icon on the desktop, all are set and
enjoy; ( still can not connect so can not enjoy )
But XTNDConnect Blue Manager 3.1b can find the Nokia 6600 without any
problem and connect to it but Pc Suite can not do it.So what can be
done ?
Sponsored Links
"Quelle Pacha" <quellepacha@mynet.com> wrote in message
news:eba98c8b.0408292246.55d36f1d@posting.google.com...
> help from you.
> Manager settings:
> . Please install PC Suite for your Nokia phones;( done )
> . After Installation, there will have two icons in the system tray
> (done )
> . Install Blue Manager, end user can download this version from
> . After installation and rebooting system, please run Blue Manager,
> 3650, select 'Trust Device' to pair computer with phone; ( done for
> 6600 )
> . Please check the Bluetooth virtual serial COM port, in Blue Manager,
> . Double click the left icon in the system tray to open one dialog
> window named 'Connection Properties' to select right port to connect
> to, ( Done )
> . After selecting the right port there will have a jump out dialog,
> . Double click the application icon on the desktop, all are set and
> done ?
firstly, download mrouter3 beta...from here
http://www.intuwave.com/index.php?page=105
then install it over your existing pc suite....it will replace the existing
mrouter software....
once installed and running you have to setup a COM port in mrouter3 and
according to your info, you should create a serial port (port 30) as this is
your serial com port.
after that mrouter3 will connect your phone and pc suite successfully...
cheers ;)
Reply to a_dude
There are 1329 identified and unidentified users. To see the list of identified users, Click here.
Sponsored links
