Front audio jack not working
Last response: in Components
Related ressources:
- ForumFront audio jack is not working
- ForumFront Panel Audio Jack Not Working
- ForumFront audio jack not working
- ForumMy front panel audio jack is not working
- ForumFront audio jack still not working ?
- ForumMy front audio jack not working in windows7
- ForumFront panel audio jack is not working
- ForumAudio jack in front panel not working
- ForumFront Panel Audio Jack - Not Working ?
- ForumFront Panel Audio and Mic jack are not working
- ForumAntec One front panel audio problem, no Jack Sensing
- ForumFront audio jack only one channel working
- ForumFront panel headphone jack only works until audio stream changes
- Forum212 evo fan replacement
- ForumMy mouse and keyboard are not working
- ForumNzxt source 210 front intake
- ForumControl audio output and volume
- More resources
Read discussions in other Components categories
I've made sure that the headphones are not muted in the lower right hand corner icon. I went to the BIOS screen and found out that even with my headphones plugged into the jack, I have found out that in the BIOS screen of my ASROCK Z77 extreme 4 motherboard it says that they are unplugged. I looked inside the case to make sure I plugged in the audio jack to the motherboard, and I have. I've looked at the other posts with the same problem, and nothing seems to fit. Help!
