Closed Solved
Adequate power supply for new mid-range build
Hello,
I am planning to construct a new mid-range computer for games and general use.
List below:
http://secure.newegg.com/WishList/PublicWishDetail.aspx?WishListNumber=29439268
Short version: i5 3570-K, GTX 660Ti, 500W Corsair power supply.
Question: Is the 500W power supply sufficient for the rig? A newegg calculator tells me that I'll need about 450W, but other calculators online suggest higher power requirements.
I have no experience picking power supplies, and wanted to verify with someone. Thank you.
5 answers Last reply Best Answer
More about adequate power supply range build
  1. Take a Corsair CX600 and will be good :)
    If you want something more futureproof, go with a TX750 or TX850.
    - The Brownie
  2. SarBashar said:
    Hello,
    List below:
    Hi - Your sys power draw with a 660ti will be approx 300w (+ or - 15w)
    a quality 500w psu is sufficient.
    Tom
  3. ditto 500watts would be ample for such a configuration.
  4. Best answer
    For a system using a single GeForce GTX 660 Ti graphics card NVIDIA specifies a minimum of a 450 Watt or greater power supply that has a maximum combined +12 Volt continuous current rating of 24 Amps or greater and that has at least two 6-pin PCI Express supplementary power connectors.
    Total Power Supply Wattage is NOT the crucial factor in power supply selection!!! Total Combined Continuous Power/Current Available on the +12V Rail(s) rated at 45°C - 50°C ambient temperature, is the most important factor.
    You may find power supplies on the market that supply more than enough Wattage to run the system. However, some of them lack Sufficient Amperage capacity on the critical +12 Volt rail, which is necessary to properly power the critical components in the system (i.e. CPU and GPUs). This is the reason why graphics card manufacturers overstate the power supply wattage, usually by at least 50 Watts, in an attempt to take into account some of those power supplies that have the weaker +12 Volt rail(s).
    The Corsair Builder Series CX500 V2 (CP-9020047), with its maximum combined +12 Volt continuous current rating of 38 Amps and with two (6+2)-pin PCI Express supplementary power connectors, is more than sufficient to power your system configuration with a single GeForce GTX 660 Ti graphics card.
  5. Best answer selected by SarBashar.
Power Supplies Build Components
