T techno4229 Honorable Jun 27, 2012 8 0 10,510 Jun 30, 2012 #1 I recently bought two 7750 sapphire graphics cards(cross fired) and when i play games i get a display error and it freezes and reloads, help please
fantastik250 Distinguished Mar 19, 2011 2,437 0 20,160 Jun 30, 2012 #2 Edit, from seeing the 7750, it doesn't use a crossfire bridge But it's quite possible to crossfire. Also, you should update both cards with the new 12.6 drivers from AMD (not BETA) Upvote 0 Downvote
T techno4229 Honorable Jun 27, 2012 8 0 10,510 Jun 30, 2012 #3 doesn't need uses motherboard, and is up to date as of today this morning. Upvote 0 Downvote
T techno4229 Honorable Jun 27, 2012 8 0 10,510 Jun 30, 2012 #4 So, disable crossfire? Upvote 0 Downvote
fantastik250 Distinguished Mar 19, 2011 2,437 0 20,160 Jun 30, 2012 #5 You sure both cards have the same driver? Check with GPU-Z http://www.techpowerup.com/gpuz/ Download, install. Make sure crossfire is enabled. Open GPU-Z. Then in GPU-Z look at the Driver Version. You can look at card number two by going to the bottom of the GPU-Z program and clicking on the little black arrow. Upvote 0 Downvote
T techno4229 Honorable Jun 27, 2012 8 0 10,510 Jun 30, 2012 #6 Yes says |ATI Crossfire| - "Enabled (2 GPUs), UPLS active" and check both cards Side note *could it be because windows is not up to date all the way?* Upvote 0 Downvote
fantastik250 Distinguished Mar 19, 2011 2,437 0 20,160 Jun 30, 2012 #7 Not too sure, you may want to update windows though. Also, if possible update your motherboard BIOS and/or chipset driver, if any. Upvote 0 Downvote
T techno4229 Honorable Jun 27, 2012 8 0 10,510 Jun 30, 2012 #8 I updated my bios and chipset driver today as well but im going to wait for windows to finish all the way and get back and find out Upvote 0 Downvote
