Help required please
I have a quad core pc, 8Gb memory and two ATI Radeon HD 4300/4500 Series graphics cards installed. the monitor plugs
into the back of one of these cards.
I believe th pc is quite good spec, but struggle even playing some older games from 3 yrs ago, It will only play anno
2070 on its lowest graphic setting and still jumps abit on the graphics.
Is it better to bin both cards and buy a decent ish one if so what will fit into it and atleast be able to play games in a half
decent way, I'n not a gamer but would like to when i want too?
Or alternatively is there something i can change in settings to make the, work better, not even sure if the twomake any difference
or shall i just remove one, help please......................................
the spec for my pc is:
PC Pitstop Active X Build 211
Browser MSIE 9.0
System OS Windows 7 Ultimate x64
System OS Install Date 4/15/2010 1:45:27 AM
System Make To Be Filled By O.E.M.
System Model To Be Filled By O.E.M.
System Serial Number
Main Board Make ASRock
Main Board Model ALiveXFire-eSATA2..
Main Board Version
Main Board BIOS American Megatrends Inc. Default System BIOS ACRSYS - 8000925 20090825
Processor Description AMD Athlon II X4 630
Number of Processors 4
Processor Clock Speed 2792 Mhz
Graphics Description ATI Radeon HD 4300/4500 Series
Memory Installed 8192 MBs
Memory Slots 4 slots
Memory Configuration 2048+2048+2048+2048;DIMM Unknown Synchronous
Drive Name (E) Main Drive
Drive Size (E) 476929 MBs
Drive Format (E) NTFS
DVD-RAM Model HL-DT-ST DVDRAM GH22NS50
DVD-RAM Read Speed 8467 KB/sec (48X)
DVD-RAM Write Speed 8468 KB/sec (48X)
Monitor Model Generic PnP Monitor
Monitor Resolution 1600 x 1200 pixels
Monitor Screen Size 18.7 x 10.5 inches
21.4 inches (diagonal)
Monitor Manufacture Date November 2009
Installed Hardware
Vendor Product
HL-DT-ST DVDRAM GH22NS50 ATA Device
EPSON Stylus Storage USB Device
WDC WD5000AADS-00S9B0 ATA Device
ATI Technologies Inc. ATI Radeon HD 4300/4500 Series
Standard Dual Channel PCI IDE Controller
ATA Channel 1
ATA Channel 0
ATA Channel 1
ATA Channel 0
EPSON EPSON SX600/BX600/ME 700
Built-in Infrared Device
Standard PS/2 Keyboard
Advanced Micro Devices AMD High Definition Audio Device
Microsoft High Definition Audio Device
Generic PnP Monitor
Microsoft HID-compliant mouse
Microsoft Microsoft PS/2 Mouse
Realtek Realtek RTL8168B/8111B Family PCI-E Gigabit Ethernet NIC (NDIS 6.20)
Ralink Technology Corp. Ralink RT61 Turbo Wireless LAN Card
Microsoft Microsoft Virtual WiFi Miniport Adapter
ECP Printer Port (LPT1)
Communications Port (COM1)
Epson Epson ESC/P-R
Advanced Micro Devices AMD Athlon(tm) II X4 630 Processor
Microsoft UMBus Enumerator
Microsoft High Definition Audio Controller
ATI ATI I/O Communications Processor SMBus Controller
ATI ATI I/O Communications Processor LPC Controller
ATI ATI I/O Communications Processor PCI Bus Controller
PCI bus
PCI standard host CPU bridge
PCI standard PCI-to-PCI bridge
Microsoft Microsoft ACPI-Compliant System
Standard OpenHCD USB Host Controller
USB Root Hub
Microsoft USB Printing Support
USB Root Hub
Compatible USB storage device USB Mass Storage Device
USB Root Hub
USB Root Hub
USB Composite Device
Standard Enhanced PCI to USB Host Controller
USB Root Hub
USB Root Hub
8 answers Last reply
More about help required please
  1. Hi
    So your PC has two dedicated HD4300 or HD4500 series graphics cards installed? If so do you know what model they are and if they are running in crossfire mode?
    I also didn't see a mention of your PC's power supply or a budget?
    Thanks.
  2. Hiya omgitzfatal, sorry I've tried to download some free programs to see if I can find out exactly whats inside.
    I am more than cabable of popping cover off to see if there is anything on the cards and also the power supply.
    As everyone, I'm on a budget but I use the pc every night, so I would just have to spend what I need to make it work right,
    ans maybe a suggestion for making it work better lol. I will just have to tell the wife "I need it".........
    According to this program it says CrossFire Disabed.
    AMD Athlon II X4 630 67 °C
    Propus 45nm Technology
    8.00 GB Dual-Channel DDR2 @ 265MHz (4-4-4-12)
    ASRock ALiveXFire-eSATA2.. (CPUSocket) 71 °C
    Acer X223HQ (1920x1080@59Hz)
    ATI Radeon HD 4300/4500 Series (ASUStek Computer Inc) 55 °C
    ATI Radeon HD 4300/4500 Series (ASUStek Computer Inc) 57 °C
    CrossFire Disabled
    Cores 4
    Threads 4
    Name AMD Athlon II X4 630
    Code Name Propus
    Package Socket AM3 (938)
    Technology 45nm
    Specification AMD Athlon(tm) II X4 630 Processor
    Family F
    Extended Family 10
    Model 5
    Extended Model 5
    Stepping 2
    Revision BL-C2
    Instructions MMX (+), 3DNow! (+), SSE, SSE2, SSE3, SSE4A, AMD 64
    Virtualization Supported, Disabled
    Hyperthreading Not supported
    Fan Speed 3924 RPM
    Bus Speed 199.5 MHz
    Rated Bus Speed 797.8 MHz
    Stock Core Speed 2800 MHz
    Stock Bus Speed 200 MHz
    Average Temperature 65 °C
    On the graphics side it states:
    Name Acer X223HQ on ATI Radeon HD 4300/4500 Series
    Current Resolution 1920x1080 pixels
    Work Resolution 1920x1040 pixels
    State enabled, primary, output devices support
    Monitor Width 1920
    Monitor Height 1080
    Monitor BPP 32 bits per pixel
    Monitor Frequency 59 Hz
    Device \\.\DISPLAY14\Monitor0
    GPU RV710
    Device ID 1002-954F
    Subvendor ASUStek Computer Inc (1043)
    Current Performance Level Level 1
    Current GPU Clock 1198 MHz
    Voltage 1.120 V
    Voltage 1.120 V
    Technology 56 nm
    Die Size 73 nm˛
    Transistors 242 M
    Release Date Sep 30, 2008
    DirectX Support 10.1
    DirectX Shader Model 4.1
    OpenGL Support 3.0
    Bios Core Clock 600.00
    Bios Mem Clock 400.00
    Temperature 56 °C
    Core Voltage 1.120 V
    Crossfire Disabled
    BIOS Version 113-AB78700-104
    ROPs 4
    Shaders 80 unified
    Memory Type HyperMemory
    Bus Width 64 Bit
    Pixel Fillrate 2.4 GPixels/s
    Texture Fillrate 4.8 GTexels/s
    Bandwidth 6.4 GB/s
  3. Alright :)
    If you download a (Free) program called GPU-Z and install it, it should tell you the actual model of the graphics card(s) rather than just the family (E.G HD4300).
    Next I'd suggest enabling Crossfire, Crossfire combines the graphics processing power of more than one card (up to 4) which increases performance, this may be enough to get you playable frame rates in the games you play.
    To do this, right click on the desktop, select Catalyst control centre, after that has loaded choose "Advanced View" then choose "Gaming" from the menus on the left and then choose AMD crossfire configuration, then tick the box to enable crossfire.
    As a side note I noticed the program you used to bring up the specs of your PC lists the CPU temperature as 67C (!) which is really quite hot for that CPU, I'd recommend verifying that with a program called Hardware monitor
    http://www.cpuid.com/softwares/hwmonitor.html
  4. Hello again and many thanks for your replies.
    I have the pc in a lower cabinet and the cover was off and a side fan unplugged but will do as you suggested.
    I hae popped the card out and both have HD4350 on them and the power supply states Max 600W
    Hope this helps yout help me more.
    I will await your reply then have a bash at the crosswire thingy, and again many thanks!
  5. Probably throttling a bit due to excessive heat. PCs need airflow cant just stick it in a cubbyhole. Take it out of the cabinet and let it get air.
  6. Yeah definitely have a crack at crossfire, to be honest two HD4350's in crossfire is still pretty weak and easily superseded by a newer low end graphics card.
    Having said that if crossfire gives you the performance then you've not spent money unnecessarily.
    On the power supply there should be a label detailing information about its output. On that label should be "+12V" and below that should be an amperage amount and a wattage amount.
    Also if you could tell us the make and model that would be helpful. :)
    Thanks.
  7. Well it appears to be running a bit smoother, beter than it was last night now I've changed the crossfire
    thing, if I were to get rid of these two cards, what wuld you suggest to replace them/it, and can aso upgrade the power supply too as I know they not too sill on costs, working on a budget of around
    £150 to £250 ish.
    All the details I can see on power supply are Winpower Model ADK-750
    Will obviously be telling the wife the lower end costs of a new graphic card.......................
  8. Ok then, if you want better performance here are a few suggestions:
    PSU: http://www.overclockers.co.uk/showproduct.php?prodid=CA-147-AN&groupid=701&catid=123&subcat=1088
    GPU: http://www.overclockers.co.uk/showproduct.php?prodid=GX-163-MS&groupid=701&catid=56&subcat=1866
    No point going high end for the graphics card as your current CPU would bottleneck it.
    If the CPU temp really is 67C then grab a better case and CPU cooler if you can, 67C for that CPU is hot even under load.
Graphics Cards Graphics
