Hello all TH techs. I want to disclose that I am new at building right away and this is only my second system (first one was a $350 PC for my parents). Please see the parts list, which I hope no one criticizes too much. During the build I had a couple of problems, but most frustrations came after the rig was finalized. First I couldn't figure out how to enable the Intel Smart Response technology (separate short thread in RAID section), on which I gave up after a day, but now I am having problems with my audio - only in games.
Sporadically certain sounds are missing, but the background music is always fine. In some games, I was even able to isolate certain actions that have no sounds and certain ones that always do - Fallen Earth, only make footsteps sounds when strafing right or spinning in place. This makes me think that the problem is due to a conflict of different channels. I tried to research online, but most likely lack the technical expertise in this area to recognize valuable information.
I am assuming the only parts that could be in conflict are the motherboard audio and the video card audio. I didn't see any conflict in the Device manager, and my BIOS only has option to disable HD Audio, which takes away all sound from my regular PC use. What troubleshooting steps should I be taking?
System:
http://www.newegg.com/Product/Product.aspx?Item=N82E16811163181
http://www.newegg.com/Product/Product.aspx?Item=N82E16814161404
http://www.newegg.com/Product/Product.aspx?Item=N82E16817139011
http://www.newegg.com/Product/Product.aspx?Item=N82E16813157293
http://www.newegg.com/Product/Product.aspx?Item=N82E16835103065
http://www.newegg.com/Product/Product.aspx?Item=N82E16822136769
http://www.newegg.com/Product/Product.aspx?Item=N82E16820227757
http://www.newegg.com/Product/Product.aspx?Item=N82E16827136247
http://www.newegg.com/Product/Product.aspx?Item=N82E16832116986
http://www.newegg.com/Product/Product.aspx?Item=N82E16819116504
http://www.newegg.com/Product/Product.aspx?Item=N82E16820231558
Appreciate any advice in advance as always.
System:
