Will my 700-watt power supply be able to handle this?
Amd fx-8350 4.0 ghz
ASrock 970 extreme3
Amd radeon HD 7850 crossfire
8gb DDR3 1600mhz RAM
1TB 7200 rpm hard drive
DVD burner
FLOPPY DRIVE (if there is enough power
7 answers Last reply
More about will watt power supply handle this
  1. It should be able to run a 7850 crossfire (Requires at least a 650 watts power supply) and you'll need 2 x PCI-Express 6 Pin connectors.
    But give us more information about the Power Supply to tell you if it does support a Crossfire.
    Really need to know more about the power supply. Also, are you leaving everything stock or overclocking at all?
  3. I may overclock a bit
  4. The power supply is a GS700
  5. With that PSU you can run a 7850 Crossfire. It has 2 x PCI-E 6+2 Pin connectors and a +12V rail of 56 Amps. So you won't have any problems, and still be able to overclock.
    Thank you very much
  7. agreed, a GS700 will hold up.
Power Supplies AMD Components
