HELP! Will This Build WORK??
Last response: in Systems
August 20, 2012 4:42:47 AM
:hello:  Right so basicially, I need to find out if these components will work together and fit in the case. also if there's any recommendations to other parts better and cheaper.. I've taken computers apart and used thermal paste before ect, but this is my first complete build. DO I NEED TO PUT THERMAL PASTE ON THE PROCESSOR? If so will the thermal paste below work?
List of components:-
Thermal Paste (IDK IF NEEDED)
Arctic Silver 5 3.5g Thermal Paste
http://www.amazon.co.uk/Arctic-Silver-3-5g-Thermal-Past...
MOTHERBOARD - ASRock P67 Pro3 - motherboard - ATX - LGA1155 Socket - P67 - LGA1155 Socket - MOTHERBOARD
http://www.google.co.uk/products/catalog?hl=en&safe=off...
GPU - (Graphics card) EVGA GTX660Ti NVIDIA Graphics Card - 2GB
http://www.scan.co.uk/products/evga-gtx-660-ti-28nm-600...
CPU (Processor) Intel Core i5 2400 3.1GHz Socket LGA 1155 6MB L3 Cache Retail Boxed Processor
http://www.ebuyer.com/251595-intel-core-i5-2400-3-1ghz-...
Power Supply - Corsair CMPSU-750AXUK Professional Series Gold 750W Power Supply
http://www.amazon.co.uk/dp/B003QP417E/?tag=hydra0b-21&h...
RAM - Corsair CMZ8GX3M2A1600C9 8GB 1600MHz CL9 DDR3 Vengeance Memory Two Module Kit
http://www.amazon.co.uk/Corsair-CMZ8GX3M2A1600C9-1600MH...
CASE -Vengeance® C70 Mid-Tower Gaming Case — Military Green
http://www.corsair.com/vengeance-c70-mid-tower-gaming-c...
BLUE RAY DVD DRIVE
http://www.amazon.com/Samsung-12XReadable-DVD-Writable-...
Thanks,
Dan. :lol:
More about : build work
August 20, 2012 5:00:00 AM
You do not need to purchase any thermal compound if you're not going to overclock. And even then if you buy an extra fan like the Hyper 212 Evo - the paste included is way better than Arctic Silver.
That PSU is way overkill for that setup - you could theoretically go with a really strong 550W PSU for a 660TI. And then it's also pointless to purchase a P67 motherboard anymore - go with an H77 and an i5-3450.
August 20, 2012 5:37:16 AM
Thanks man:)  So could i use the H77 Motherboard and get a 550W PSU and use the rest of the components I've listed?
August 20, 2012 5:40:52 AM
Yup. That will work. Make sure you use the i5-3450 - there's no reason to get anything else between that and the 3570K. You could probably also scale back the case a bit - the C70 is nice and Corsair makes great cases but it's way overkill for this setup. You could go with a 300R and save some money there.
August 20, 2012 5:52:09 AM
:) Thanks soo much, I'll look forward to doing my first build:)  (pretty much lol)
I guess your right about the case and some of the components, I got exicted, and went a bit over the top lol.
August 20, 2012 6:16:17 AM
Oh when you said H77? ASRock H77? or?
August 20, 2012 9:47:08 PM
dantheman1996 said:
Sorry again about this, just wondering is there a good/decent GPU for gaming thats cheaper then this
EVGA GTX660Ti NVIDIA Graphics Card - 2GB but is still quite good?
Yup - good brand and good card.
