Printer problems
Last response: in Digital Camera
Anonymous
a b α HP
September 7, 2005 7:49:42 PM
Archived from groups: rec.photo.digital (More info?)
First of all, please pardon me if this has already been
discussed. I didn't find it in recent threads.
I have a Nikon D70 which gives pretty decent photos for the
amateur photographer that I am. I recently purchased an
inexpensive HP 4215V "all-in-one", primarily to use as a fax
machine and office printer. However, I've had several folks ask
for prints of digital pictures I've taken.
The problem is the images, which appear bright and smooth on
screen, invariably print out as grainy, low color images on
paper. I selected the highest resolution and HP glossy paper
which is what I'm trying to use.
Any advice would be deeply appreciated.
Regards,
Robert L Bass
Bass Burglar Alarms
The Online DIY Store
http://www.BassBurglarAlarms.com
More about : printer problems
Anonymous
a b α HP
September 8, 2005 3:56:05 PM
Greetings Bass,
Sounds like you may have used a low setting in your camera when you
captured your images. If that is the case, the quality of the prints
may be less than hoped. Although, with the D70 just about all of them
should be pretty good. Anway, make sure the file is of a quality high
enough to make prints of the size you want.
Also, if you are going to use Kodak paper, I suggest Ultima, go to the
Kodak web site and download and install the EasyShare Software. It
includes something called One Touch. Kodak has gone to the trouble of
acquiring just about every printer on the market and testing them for
all the Kodak Inkjet Papers. If you have a a good file with enough
resolution for a good print, the current driver installed for your
printer, and you use Kodak Ultima Paper or Premium Paper with EasyShare
software, your prints should be excellent. If not and you want to use
Kodak Paper anyway, go to the Kodak Inkjet site and review the settings
for your printer with any number of paper types. Reset your printer
driver accordingly and you should get excellent results as well.
http://www.kodak.com/go/inkjet
Look to the left of that page to find the Printer Settings link.
Good luck, let me know if you have any trouble.
Ron Baird
Eastman Kodak Company
September 8, 2005 6:09:26 PM
> Regards,
> Robert L Bass
I have the similar HP 4215xi, and get excellent photo prints from it. First of all, make
sure that the pixel count of your photos allows at least 200 pixels per inch in both the
height and width of the print, preferably at least 250 ppi. Then choose the right
printing mode in the printer software; the Professional Quality Photos mode works great
for me. You didn't mention what program you are printing from, which can make a
difference. I normally use Paint Shop Pro, and sometimes use the free Kodak EasyShare
software, with Kodak paper instead of HP paper. Kodak paper is less expensive, and works
vey well with HP inks. Don't use refilled ink cartridges for photos.
