The fan in my power supply is making noise
Last response: in Components
January 4, 2013 2:21:09 AM
the fan in my power supply makes a grinding noise not constantly but regularly sometimes soft sometimes loud but when you tap the desk it quits for a min then starts making noise again.when i shut off my computer for the night and then when i start it back up its quiet for a while.Can anything be done without buying a new power supply. thank you.
January 4, 2013 2:29:39 AM
Have you tried opening it up? There could be some cables coming down and touching the PSU fan. If that's not the problem, then it could just be a faulty PSU.
m
l
a c 1167 ) Power supply
January 4, 2013 3:41:06 AM
Most likely the lubricating film on the PSU's cooling fan bearing has evaporated.
If the PSU is till under warranty you can RMA it.
m
l
