Solved
Need good quality power supply ?
I need agood quality PSU for ATI 6990 , any recommend ?
4 answers Last reply Best Answer
More about need good quality power supply
  1. Best answer
  2. Use this tool to determine the correct wattage needed for you PSU:
    http://www.extreme.outervision.com/psucalculatorlite.jsp
    Then checkout this link:
    http://www.tomshardware.com/forum/324368-28-computer-power-supplies-guide
    When I buy a PSU, I take the minimum wattage from the power supply calculator and double it. (most PSU's are most efficient at about 50%-60% of their rated load). I then pickup something with a single +12v rail, that's 80+ certified, usually from Seasonic or PC Power and Cooling (but there are many other great brands, always check the reviews)
    Make sure that your selected PSU has the proper power connectors for your ATI 6990, probably 2x8 pin.
  3. Thank you guys , I bought crosair TX 750w
Power Supplies ATI Components Product
