Hello, hoping you can help and suggest possible options for my build.
Budget: $1500-$1700 (Dont need peripherals, ie monitor, keyboard...)
Use: Gaming, Video/Pics/Music/Programming/Web Surfing
Mobo: Gigabyte Z77X-UD3H ATX
CPU: Intel Core i7 3770K Unlocked Quad Core Processor
RAM: Kingston HyperX KHX1600C9D3K2/8GX 8GB 2X4GB DDR3-1600 XMP Dual Channel Memory Kit
Case: Fractal Design Define R3 Black ATX Mid Tower Silent Computer Case
Cooling: Corsair Cooling Hydro Series H80 High Performance CPU Cooler System
HDD: Seagate Barracuda 7200 1TB 3.5IN 64MB Cache SATA3 Internal Hard Disk Drive HDD
SSD: Intel 520 Series 240GB 2.5IN SSD MLC 25nm SATA3 Solid State Disk Drive
PSU: Corsair Professional HX750W 750W ATX 12V 62A 24PIN ATX Modular Power Supply Active PFC 140mm Fan
GPU: MSI GeForce GTX 670 OC PE 1079MHZ 2GB 6.0GHZ GDDR5 2xDVI HDMI DisplayPort PCI-E Video Card
DVD: ASUS DRW-24B1ST 24X SATA DVD Writer
Im still debating on 2 items:
1) Case: Thinking of the Fractal R3 but may wait for the R4 to be in stock (Canada) or should I go for the Antec P280 or Eleven Hundred?
2) Cooling: The Corsair listed or will the Coolmaster Hyper 212 Evo do the trick (thinking OC to 4.0-4.2GHz)?
Thanks in advance.
Thanks in advance.
