G
Guest
Guest
I just built a new computer and it worked great for 2 weeks no problems. But then one day i decided to do some cable management. so i unplugged everything and re routed all my cables to make it neat. i took my graphics card out and only my graphics card and set it on a rubber and wood ledge to sit while i did the cables. Then i plugged everything in exactly where they are supposed to be and was done. Just a note i wasn't wearing an anti static wrist band. So i plug everything in the back of my computer and power on. all my leds turn on. and all the lights on my motherboard turn on. But nothing on the screen came up. No pc beeps or anything. So i checked my processor and nothings burnt up. I made sure my ram was pushed down and i made sure my graphics card had power and was pushed down all the way. I put my finger on the fan for my graphics card and it wasnt spinning. but at the same time on my motherboard the cpu light was lit up indicating an issue. Any ideas of what it could be? and if i need to give anymore detail pls say so. im rlly hoping i get this solved because i couldnt find any thread that gave me good info. my components are listed below
motherboard: asus rampage extreme 4
processor: sandy bridge 3.6ghz lga 2011
power: xion 850w blue led
graphics card: nvidia geforce 670 2gb
ram: g skill ddr3 2400 16 gb quad channel
And just another note. the leds and fan turn on for my power. i rmad my graphics card but i just wanna know if t could be anything else. i have all the packaging for my ram and cpu and motherboard incase its one of those. ty
