MikGW
37
I'm using the Asrock Extreme4 mobo, and the gtx 670. I also have HD 4000 graphics b/c of the 3570k CPU. I just installed Arkham City, and I'm getting a score of 20 (fps I assume) on the benchmarks tests in game. I've concluded I'm mistakenly using the onboard graphics instead of the 670. Does anyone know how to disable the HD 4000 in this specific bios, on this mobo?
First off you need to make sure that your display is plugged into the graphics card and not the motherboard.
Second, you have to disable the HD 4000 graphics in the BIOS. What motherboard are you using?
JKatwyopc
