Help me build plz
Hi,
I am looking for a gaming pc around $1000 budget. Prefer intel cpu, and radeon graphics card, not looking to overclock. Want to make sure pc isnt overheating, had problems previously. No need for OS or monitor, will need keyboard and mouse.
Could someone provide build for me to take a look? Thanks.
10 answers Last reply
More about help build
  1. Ill build you one up just a second.
  2. kmaxdude said:
    Hi,
    Sure, buddy here you go:
    CPU: Intel Core i5-3570K 3.4GHz Quad-Core Processor ($189.99 @ Microcenter)
    CPU Cooler: Cooler Master Hyper 212 EVO 82.9 CFM Sleeve Bearing CPU Cooler ($28.98 @ NCIX US)
    Motherboard: Asus P8Z77-V LK ATX LGA1155 Motherboard ($124.99 @ NCIX US)
    Memory: Corsair XMS3 8GB (2 x 4GB) DDR3-1600 Memory ($42.99 @ Newegg)
    Storage: Western Digital Caviar Blue 1TB 3.5" 7200RPM Internal Hard Drive ($79.99 @ NCIX US)
    Video Card: EVGA GeForce GTX 670 2GB Video Card ($368.00 @ Newegg)
    Case: Cooler Master HAF 912 ATX Mid Tower Case ($49.49 @ SuperBiiz)
    Power Supply: PC Power & Cooling 500W ATX12V Power Supply ($57.08 @ NCIX US)
    Keyboard: Logitech MK710 Wireless Ergonomic Keyboard w/Optical Mouse ($69.99 @ Amazon)
    Total: $1011.50
    That build is extremely powerful, the only thing it needs to be perfect is an SSD witch i did not include so you could afford a more powerful video card, if you want an SSD you're gonna have to drop the GTX670 and get a 7870....i don't think that would be smart, look: http://www.anandtech.com/bench/Product/598?vs=548
  3. Here this fits your needs perfectly i5 3570K 3.4GHz - 230$
    http://www.newegg.com/Product/Product.aspx?Item=N82E16819116504
    ASRock Z77 extreme 4 - 135$
    http://www.newegg.com/Product/Product.aspx?Item=N82E16813157293
    Corsair 8GB DDR3-1600 - 50$
    http://www.newegg.com/Product/Product.aspx?Item=N82E16820145324
    Western Digital Caviar Blue 500GB 7,200 RPM SATA 6.0Gb/s 3.5 - 70$
    http://www.newegg.com/Product/Product.aspx?Item=N82E16822136769
    CORSAIR Enthusiast Series TX750-110$
    http://www.newegg.com/Product/Product.aspx?Item=N82E16817139021
    HAF912 Mid Tower ATX Computer Case- 60$
    http://www.newegg.com/Product/Product.aspx?Item=N82E16811119233&Tpk=haf%20912
    Samsung 22X DVD±RW Burner - $17
    http://www.newegg.com/Product/Product.aspx?Item=N82E16827151244
    XFX FX-795A-TNBC Radeon HD 7950-350$-320 after rebate...
    http://www.newegg.com/Product/Product.aspx?Item=N82E16814150601
    this comes out to 1022$ but will be a awsome build that will support all the future upgrades that you would ever want, but if you want you can smack the power supply down to cosair 650...
  4. thanks for posts, i decided to build my "own" and came up with the following list, any suggestions or problems with it? thanks again
    http://pcpartpicker.com/p/fc31
  5. Don't get coolermaster's psu's they have a bad rep id look at something cosair, antec, seasonic, pc power and cooling..... also at least bump up to a z77 mobo it isnt that much more,otherwise pretty decent build
  6. sweet thanks, quick question about pcpartpicker.com, after i make my list i need to go to indiviual part and buy from there? there is no quick and easy buy all at the same time way?
  7. CPU: Intel Core i5-3570K 3.4GHz Quad-Core Processor ($189.99 @ Microcenter)
    Motherboard: ASRock Z77 Extreme4 ATX LGA1155 Motherboard ($134.99 @ Microcenter)
    Memory: G.Skill Sniper Low Voltage Series 8GB (2 x 4GB) DDR3-1600 Memory ($44.99 @ Newegg)
    Storage: Seagate Barracuda 2TB 3.5" 7200RPM Internal Hard Drive ($99.99 @ Newegg)
    Storage: Crucial M4 64GB 2.5" Solid State Disk ($69.99 @ Newegg)
    Video Card: Gigabyte Radeon HD 7950 3GB Video Card ($337.55 @ Newegg)
    Power Supply: Corsair 600W ATX12V Power Supply ($46.98 @ NCIX US)
    Optical Drive: Asus DRW-24B1ST/BLK/B/AS DVD/CD Writer ($19.98 @ Outlet PC)
    Total: $993.95)
    CPU - I was thinking I'd get you a non-overclocking 3450 but their not on sale.
    GPU - Managed to get you a 7950 which trades blows with the 660ti but ultimately comes with 1 more GB of RAM and more memory interface band-width, though the memory is slower
    Cooler - I assumed that IVY wouldn't need massive cooling at stock speeds to I think the Intel cooler win run you fine there.
    Storage - I managed to get you a 2TB seagate 7200RPM AND A 64GB Crucial M4 SSD for Windows and maybe 1 or 2 apps.
    PSU - Corsair 80-plus certified at 600W, you shouldn't run into any problems with power -- most of your components are low power.
    MOBO - I chose Asrock over Asus for a few reaons. #1 the asrock comes with a heatsinked VRM opposed the Asus which only heatsinks one portion. The Asrock comes with two more SATA 6gb ports and the Asrock comes with Gold Capacitors -- longer MOBO life.
    EDIT -- I'm DUMB LOL --- Forgot to put link -- http://pcpartpicker.com/p/fcb3
  8. for the power the card says min of 500watt, then memory i was thinking something around 200 watt, then everything else so i was aiming for 750. What is the proper way to calculate this? Dont want to have any power issues. Thanks for all the help.
    Don't worry, first of all, minimums on GPUs often overshoot by 50W-100W -- what matters if efficiency, specifically, an 80+ certification on the PSU. Your system will run fine on my 600 or even a 500w. I actually got low-voltage RAM as well.
    http://images10.newegg.com/BizIntell/tool/psucalc/index.html -- Here is a PSU calculator
    I actually did the whole calculation out, using a higher-end GTX 680 as the card, and got a recommendation of a 516W PSU.
    If you are looking to SLI later, a good 650W will run 660ti's at about 80% load of the PSU, which is optimal.
  10. kmaxdude said:
    Hi,
    http://www.amazon.com/gp/product/B006TVQTHW/ref=ox_sc_act_title_1?ie=UTF8&smid=ATVPDKIKX0DER $63.21 & this item ships for FREE with Super Saver Shipping
    Antec Three Hundred Two Gaming Case, Black Front I/O ports: - 2 x USB 3.0
    http://www.amazon.com/XFX-ATX-550-Power-Supply/dp/B004RJ8EKI/ref=sr_1_1?s=pc&ie=UTF8&qid=1345523089&sr=1-1 $65.99 & this item ships for FREE with Super Saver Shipping
    XFX ATX 550w 80+ Bronze Power Supply - P1550SXXB9
    http://www.newegg.com/Product/ComboDealDetails.aspx?ItemList=Combo.1026118 $266.98 save: $13.00
    Intel Core i5-3470 Ivy Bridge 3.2GHz (3.6GHz Turbo Boost) LGA 1155 77W Quad-Core Desktop Processor Intel HD Graphics 2500 BX80637i53470
    ASRock B75 PRO3 LGA 1155 Intel B75 HDMI SATA 6Gb/s USB 3.0 ATX Intel Motherboard
    http://www.newegg.com/Product/Product.aspx?Item=N82E16820231544 $43.99 FREE SHIPPING
    G.SKILL Ares Series 8GB (2 x 4GB) 240-Pin DDR3 SDRAM DDR3 1600 (PC3 12800) Desktop Memory Model F3-1600C9D-8GAO
    http://www.amazon.com/Sony-AD-7280S-0B-Internal-Drive-Black/dp/B0057FRTPW/ref=pd_cp_e_0 $20.96 & eligible for FREE Super Saver Shipping on orders over $25
    Sony AD-7280S-0B 24x SATA Internal DVD+/-RW Drive (Black)
    http://www.amazon.com/Seagate-Barracuda-3-5-Inch-Internal-ST1000DM003/dp/B005T3GRNW/ref=sr_1_9?m=ATVPDKIKX0DER&s=pc&ie=UTF8&qid=1345523575&sr=1-9 $86.63 & this item ships for FREE with Super Saver Shipping
    Seagate Barracuda 7200 1 TB 7200RPM SATA 6 Gb/s NCQ 64MB Cache 3.5-Inch Internal Bare Drive ST1000DM003
    http://www.amazon.com/MSI-R7950-TWIN-FROZR-3GD5/dp/B007NG3WR2/ref=sr_1_3?ie=UTF8&qid=1345523755&sr=8-3&keywords=7950 $349.99 & this item ships for FREE with Super Saver Shipping | Price after rebate: $329.99
    MSI AMD Radeon HD 7950 3GB GDDR5 DVI/HDMI/2xMini DisplayPort PCI-Express Video Card R7950 TWIN FROZR 3GD5/OC
    Total: $897.75 *not including shipping & rebates
    http://www.newegg.com/Product/Product.aspx?Item=N82E16820171646 $94.99 FREE SHIPPING
    SanDisk SDSSDP-128G-G25 2.5" 128GB SATA III Internal Solid State Drive (SSD)
Build Systems Product
