Hi everyone
My aim for the build:
HTPC
mid-level gaming
quiet for the living room.
try some newb overclocking.
Here is what I have already bought and put together so far:
SilverStone Sugo SG08
AMD A8 3870k
Corsair 64G SSD
2x4G RipJaws 1866
Sapphire HD6670 Ultimate. passive. Crossfired
Gigabyte GA-A75N-USB3
This is working fine so far however I need some advice on getting a new fan for the CPU and case in general I guess. The stock sounds like a buzzsaw.
Two problems:
1. With the passive HD in there I've had to remove the SUGO 180mm case fan.
2. The Gigabyte mobo has the CPU placed right next to the PCI slot.
I will get fancy on the cable management when as a last step.
What do you advise for cooling ? Are there cpu coolers that will help with the overall airflow as well? budget isnt much of a concern.
HTPC
mid-level gaming
AMD A8 3870k
Corsair 64G SSD
2x4G RipJaws 1866
Two problems:
