Archived from groups: rec.photo.digital (More info?)
Hi
I spent 10 days scanning borrowed family photos at high res. Not until
I'd finished did I discover that there is a fault with the scanner, and
I can't easily borrow the photos again.
There are stripes of different 'greyness', approx 2 cm wide accross the
mostly b&w photos, rather like the different stripes of green in a
newly mowed lawn. If you want to see an example, here's one; I've
reduced the resolution for the internet.
http://homepage.ntlworld.com/tony.jeffs/junk.jpg
Any ideas on how about trying to correct it? Is it a realistic
possibility?
tonyjeffs@aol.com wrote:
> Hi
> http://homepage.ntlworld.com/tony.jeffs/junk.jpg >
> possibility?
> Thanks tony
Hi...
Perhaps my old eyes, but I can't see what you're speaking
of.
Perhaps you need to put up a larger picture, or maybe
a crop of a larger picture.
"Ken Weitzel" <kweitzel@shaw.ca> wrote in message news:RWWTe.443264$s54.66355@pd7tw2no...
> > Hi
> > http://homepage.ntlworld.com/tony.jeffs/junk.jpg > >
> > possibility?
> > Thanks tony
> Hi...
> of.
I can clearly see the stripes. Are you using an LCD monitor? ;-)
Tony, it looks like a bad scanner CCD. Although I can't explain
why the stripes are so evenly distributed. Was this photo scanned
top to bottom or side to side, i.e. are the stripes appearing
horizontally or vertically out of the scanner?
Also, were you scanning at or beyond the maximum optical
resolution of the scanner (were you using interpolation)?
So if that's the scanner with the moving bar accross the middle, the
picture has bars running from top to bottom. I imagine there are two
sets of 'heads' on the bar, and one isn't set correctly.
Ken, I've faked (what looks like) an exaggerated version of the fault
here.
http://homepage.ntlworld.com/tony.jeffs/exjunk.jpg once you've seen it, you'll be able to pick out the real fault in the
real picture, in the same places, here
> Hi
> possibility?
> Thanks tony
What may work, depending on what image editing software you have, is to get a neutral gray
image (you could print one out), scan it the same way, invert the image to a negative, and
apply that as a layer to the photo images.
> > Hi
> > possibility?
> > Thanks tony
I studied the problem in Photoshop, and it appears that the effect is
worse in dark areas like the lady's blouse than in lighter areas. This
would suggest a light or flare problem with the scanner, maybe something
has been on the scanner glass that has left behind a deposit of some
sort, in vertical bands down the glass. The novel solution suggested by
Marvin probably won't work because the variations aren't a constant
density shift within the bands.
I think, sadly, you have no recourse but to re-scan the images, even
though it might be difficult to obtain them a second time. If time or
speed is a problem, you might consider using a digital camera on a copy
stand, much faster than a scanner, more portable - go to the photographs
instead of them coming to you. I guess most of the shots are 120
contact prints, and a >3MP shot will probably beat most scanners for
definition.
>possibility?
Well, if you have photoshop then it should be possible to set up a
layer mask that will adjust the brightness and/or contrast and
eliminate the banding. The hard part would be aligning the mask with
the bands. In the wildly improbable case where all photos have the
bands in the same place you could even automate the process for all
the photos.
Thanks for all the suggestions.
The trouble is, the fault isn't consistant. Although it is to do with
the heads, smooth photos are less a(e)ffected than stippled photos, and
lighter photos less than high contrast photos. It isn't even constant
in different regions of the same photo.
So - Conclusion, after trying all your suggestions and everything you &
I could think of I've given in and finally borrowed the photos again.
It was easier than I thought, although some of the better ones in
frames will require further negotiation!
