Solved
First build, need budgeting + part advice ($1,200)
I am making my first build (Gaming + programming games + modding games), with a $1,200 budget that I hope not to hit. Sadly, I've hit it already. I've gone over. And I've done way too much research on the parts. I am overclocking, and curious if I should switch to water cooling. And I didn't do much research on the ram... And I'm wondering if there are any bad parts that I've decided on. Also getting everything from newegg.
CPU: Intel Core i5-3570K - $230
http://www.newegg.com/Product/Product.aspx?Item=N82E16819116504
GPU: Asus GeForce GTX 560 - $170
http://www.newegg.com/Product/Product.aspx?Item=N82E16814121446
Mobo: Maximus V Gene - $200
http://www.newegg.com/Product/Product.aspx?Item=N82E16813131830&Tpk=maximus%20v%20gene
Ram: 2 x 8Gb Corsair Vengeance Ram - $90
Haven't seen many people use this - is there something better, cheaper?
http://www.newegg.com/Product/Product.aspx?Item=N82E16820233246
PSU: SeaSonic X Series X650 Gold - $140
http://www.newegg.com/Product/Product.aspx?Item=N82E16817151088
HDD: Western Digital Caviar Black 1TB - $110
http://www.newegg.com/Product/Product.aspx?Item=N82E16822136533&Tpk=1%20tb%20western%20digital%20caviar%206%20gb%2fs%20black
Case: Cooler Master HAF 912 - $60
http://www.newegg.com/Product/Product.aspx?Item=N82E16811119233&Tpk=haf%20912
OS: Microsoft Windows 7 Pro 64-bit OEM - $140
http://www.newegg.com/Product/Product.aspx?Item=N82E16832116992
DVD/CD Burner/Reader: Asus 24X DVD/CD Burner - $20
http://www.newegg.com/Product/Product.aspx?Item=N82E16827135204
Monitor: Acer G215 21.5" Widescreen LCD Monitor - $120
Not absolutely required unless DVI can't convert to D-Sub/VGA (old samsung monitor in my basement.. maybe I should upgrade anyway)
This monitor is weird. Acer states the monitor has a 600:1 contrast ratio, and newegg states it has ACM 20,000:1 contrast ratio. What is the difference?
http://www.newegg.com/Product/Product.aspx?Item=N82E16824009306
+ $82 for fans
Subtotal: $1,382
Shipping: $32
Warranties: $65
I plan on gaming with this computer, and overclocking.. I hope I can game on max or almost max, like 4 out of 5 or something on settings.
After all of these parts I think I may have picked a bad part or two... and I would also like some budgeting advice, parts I could switch out for cheaper, etc. Under $1,000 would be great, but $1,200 is fine, and also my max.
Intel is also a must, cause then I won't have to upgrade again in a few years, or, if we're lucky, before quantum computing is released to the last 99.999% of the population.
I'd also prefer to keep the cpu and case... I'm fine with changing other stuff...
5 answers Last reply Best Answer
More about first build budgeting part advice
  1. ill send you my parts list later on. dont have a proper computer ATM
  2. I'm thinking of switching to radeon, any ideas for about the same speed as a 560? Cause it looks like it'll be cheaper...
  3. Best answer
    http://www.newegg.com/Product/ComboDealDetails.aspx?ItemList=Combo.1021001 $151.98 save: $18.00 - $20.00 Mail In Rebates FREE SHIPPING
    Corsair Carbide Series 300R Black Steel / Plastic ATX Mid Tower Computer Case
    CORSAIR Enthusiast Series TX650 V2 650W ATX12V v2.31/ EPS12V v2.92 80 PLUS BRONZE Certified Active PFC High Performance Power Supply
    http://www.newegg.com/Product/ComboDealDetails.aspx?ItemList=Combo.1030095 $346.98 save: $18.00
    Intel Core i5-3570K Ivy Bridge 3.4GHz (3.8GHz Turbo) LGA 1155 77W Quad-Core Desktop Processor Intel HD Graphics 4000 BX80637I53570K
    ASRock Z77 Extreme4 LGA 1155 Intel Z77 HDMI SATA 6Gb/s USB 3.0 ATX Intel Motherboard
    http://www.amazon.com/gp/product/B005O65JXI/ref=ox_sc_act_title_1?ie=UTF8&smid=A2EUTVCJXLAJ4K $33.45 & this item ships for FREE with Super Saver Shipping
    Cooler Master Hyper 212 EVO CPU Cooler with 120mm PWM Fan (RR-212E-20PK-R2)
    http://www.newegg.com/Product/Product.aspx?Item=N82E16820231544 $43.99 FREE SHIPPING
    G.SKILL Ares Series 8GB (2 x 4GB) 240-Pin DDR3 SDRAM DDR3 1600 (PC3 12800) Desktop Memory Model F3-1600C9D-8GAO
    http://www.amazon.com/Lite--Super-AllWrite-Layer-Drive/dp/B002YIG9AQ/ref=sr_1_4?s=pc&ie=UTF8&qid=1345672179&sr=1-4 $17.99 & eligible for FREE Super Saver Shipping on orders over $25
    Lite-On Super AllWrite 24X SATA DVD+/-RW Dual Layer Drive - Bulk - IHAS124-04 Version C (Black)
    http://www.amazon.com/Seagate-Barracuda-3-5-Inch-Internal-ST1000DM003/dp/B005T3GRNW/ref=sr_1_9?m=ATVPDKIKX0DER&s=pc&ie=UTF8&qid=1345672350&sr=1-9 $86.63 & this item ships for FREE with Super Saver Shipping
    Seagate Barracuda 7200 1 TB 7200RPM SATA 6 Gb/s NCQ 64MB Cache 3.5-Inch Internal Bare Drive ST1000DM003
    http://www.amazon.com/Gigabyte-mini-Displayport-PCI-Express-Graphic-GV-R785OC-2GD/dp/B007PJTNYS/ref=sr_1_7?ie=UTF8&qid=1345671891&sr=8-7&keywords=7850 $229.99 & this item ships for FREE with Super Saver Shipping | Price after rebate: $209.99
    Gigabyte AMD Radeon HD 7850 2 GB GDDR5 DVI-I/HDMI/2x mini-Displayport PCI-Express 3.0 Graphic Card GV-R785OC-2GD
    http://www.amazon.com/Windows-Premium-64bit-System-Builder/dp/B004Q0PT3I/ref=pd_bxgy_e_text_b $90.30 & this item ships for FREE with Super Saver Shipping
    Windows 7 Home Premium SP1 64bit (Full) System Builder DVD 1 Pack
    Total: $1,001.31 *not including shipping & rebates
    http://www.amazon.com/VS228H-P-21-5-Inch-Full-HD-Monitor-Black/dp/B005BZNDOO/ref=sr_1_1?s=electronics&ie=UTF8&qid=1344807205&sr=1-1&keywords=asus+21.5+led+monitor $136.40 & this item ships for FREE with Super Saver Shipping
    ASUS VS228H-P 21.5-Inch Full-HD LED Monitor (Black) | 5ms; 50,000,000:1 ASUS Smart Contrast Ratio; Full 1080P with HDMI
    http://usa.asus.com/Display/LCD_Monitors/VS228HP/#overview <----- another look at that monitor
  4. Best answer selected by mr_yogurt.
New Build Systems Product
