recently my PSU went out. I picked up a corsair cx430 from Micro Center on clearance for 65 bucks for a quick fix.
i'm now thinking about doing sum upgrades and am currently going through these 2 threads trying to find a good PSU for my needs.
http://www.tomshardware.com/forum/323296-28-best-brands
http://www.eggxpert.com/forums/thread/323050.aspx
My research usually takes months and i need to take this PSU back b4 my 30 days are up so this is what i need the PSU to support or the new system
Dell Studio 540
Q8200 Core 2 quad
4 2gb ddr2 6400 ram
2 Western digital 1TB caviar black HDD
1 SSD
1 DVD/CD-RW Combo
1 Bluray/DVD/CD Combo
Not sure on GPU but thinking 7750. May change since the new PSU will have a PCI-E x 16 power line
2 PCI-E x 1 cards
1 PCI card
3 usb peripherals
1 firwire to a Profire 610
I Need...
support ATX
6 Sata power connector
1 gpu connector
1 4pin cpu
1 20+4 connector
Basically looking for good reliable brand. something under 70 bucks. preferably around 450-550 watts which should support everything safely. good longevity (my PC stays on 24/7 with no sleep mode). high efficiency would help with my power bill also. Also do you think i should go with a modular system since i'm looking for specific cables with no excess
Any help or direction would be appreciated in these last 15 with this PSU
Dell Studio 540
Q8200 Core 2 quad
4 2gb ddr2 6400 ram
1 SSD
1 DVD/CD-RW Combo
2 PCI-E x 1 cards
1 PCI card
3 usb peripherals
I Need...
support ATX
1 gpu connector
1 4pin cpu
1 20+4 connector
