Please recommend me a CPU Cabinet
Last response: in Components
January 5, 2013 10:24:06 AM
Hi
My system specs->
ASRock Z77 Extreme 4 Motherboard
Corsair Vangeance 4x1 GB RAM
Intel 3.4 GHz LGA 1155 Core i5 3570K Processor
zotac nvidia geforce gt 610 syenergy edition ddr3 2gb Graphics Card
I want to purchase a new Case/Cabinet for my PC.
Please recommend me one.
My budget for cabinet is Only Rs.4000.
If possible, please tell me a good dust-proof and that helps to keep the system cool (maybe its too much for such a little money but even if there is, please tell me).
More about : recommend cpu cabinet
a b ) Power supply
January 5, 2013 10:43:56 AM
I don't know about computer cases in your area but I will recommend you ditch the gt610 as it's not any better than the onboard graphics.
January 5, 2013 12:22:19 PM
Thanks but I already know that and I will soon purchase Radeon 7700HD and use along with it being Radeon as primary.
Nevermind that, please tell me about cases. I want to purchase from flipkart actually. So choices are not so small. :D
a b ) Power supply
January 5, 2013 12:47:06 PM
Should be some good cases, though some are a bit over budget.
Corsair 300R. 4500rs
http://www.flipkart.com/corsair-300r/p/itmd8bfzeqz4yfqc...
Coolermaster HAF912. 4800Rs
http://www.flipkart.com/cooler-master-haf-912-combat-mi...
Coolermaster elite 431+. 3812Rs
http://www.flipkart.com/cooler-master-elite-431-plus-mi...
Bitfenix Outlaw APAC edition. 4200Rs
This is one of the weirdest cases iv ever seen. Its got the whole mobo tray upside down. The Silverstone Raven series has it rotated 90 degrees but this is completely upside-down.
http://www.flipkart.com/bitfenix-outlaw-apac/p/itmdfzmr...
Bitfenix Merc Alpha. 2843Rs
http://www.flipkart.com/bitfenix-merc-alpha/p/itmd9zyvq...
January 6, 2013 11:59:43 AM
ok. Thanks.
But i am confused between Bitfenix Outlaw APAC Edition and Cooler Master HAF 912 Combat Mid Tower Cabinet.
While Cooler Master HAF 912 Combat Mid Tower Cabinet has awesome design on the other hand, Bitfenix Outlaw APAC Edition has 3 fans for better cooling.
Which one will you people recommend?
And yeah, are these fully compatible with my stuff? Bcos i dont want that i will have to stretch wires and conjust things. I want that things should properly fit.
Additional Info-> I have SAMSUNG HD161GJ as internal hard drive (Actually its from my old pc). Is it compatible with my setup and these cases?
Thanks for big help so far :)
January 6, 2013 2:35:29 PM
Anyone guys please
January 6, 2013 2:56:34 PM
Cases should not be judged by how many fans it says it comes with. The HAF 912 comes with 2 fans but has 6 spots and you can buy additional fans for those spots. Fans are really cheap too. You should check out how many fans each case can fit ;)
