Closed
Help on choosing a Power Supply
Last response: in Components
Hey, I want to build a gaming PC and I've been doing some research and the components I got now are i5-3470, EVGA GTX 660 and 4GB DDR3 RAM (I'll be adding more later). I have a 3TB HDD, might put in an SSD sometime. The place I'm buying it from quoted me a 450W Thermaltake PSU, but that seems a little weak...
Any other power supplies that anyone could recommend? I'm happy to spend a little more on a PSU, in order to protect my other components.
JellyBOMB
More about : choosing power supply
JellyBOMB
Plenty of wattage, not too keen on low end Thermaltake though
Power supply Master
JellyBOMB
Hi - The shop didn't try to sell you higher wattage than you need.
realhardtech sggests a quality 430w unit for a sys with one gtx 660.
However, Thermaltake has several 'bad' PSU models out there, and I
suggest you get a quality unit in the 450 - 550w range.
Quality brands: Seasonic, PC P&Cooling, XFX, Rosewill Capstone series,
most Cosair's, most Antecs, Enermax, & a few others. If you
post your PSU budget I'll recommend some for you to choose from.
Tom
Related ressources
Thanks for the quick replies! However, since I'm buying local (Newegg doesn't ship to South Africa D: ), my choice on components is limited. Would you guys go for, say, a Cooler Master model in around the same wattage range (I think it's 500-something)?
JellyBOMB
Power supply Master
JellyBOMB
Def no on Coolermaster (worse than TT), what other brands are available?
