Hello,
I recently got a new modem/router device from my ISP and its wifi is fairly weak (no external antennas) especially in my basement. Since wifi is no longer an option and I only have one ethernet connection to my basement I was thinking of using my old router to distribute the one ethernet connection to multiple devices. Connecting my one ethernet connection to the old router, and its port#1 to my PC in the basement works without any meddling, but the speed has taken a significant hit. Before the second router I was getting ~30-40Mbps from my ISP. With the second router it is reduced to ~10-20Mbps. Both routers I assume are capable of at least 100Mbps (probably even 1Gbps?). The older router is a Linksys WRT54G which can do 54Mbps wirelessly so I assume it can exceed 10-20 wired.
I tried giving the second router a static IP with DHCP off, but it did not seem to make a difference. I don't know if I set it up correctly, however. The modem/router uses 192.168.0.xxx while the second uses 192.168.1.xxx so I do not think there is any conflicts in the DHCP.
Any ideas on how I can fix this speed issue? Or am I setting up this wrong?
Thanks for your help .
