Approximate Purchase Date: e.g.: Within Next two weeks
Budget Range: 600-1500
System Usage from Most to Least Important: (e.g.: Folding@Home, gaming, surfing the internet, watching movies)
Are you buying a monitor: Yes
Do you need to buy OS: Yes
Preferred Website(s) for Parts: newegg/cheap but good sites.
Overclocking: Maybe
SLI or Crossfire:Maybe
Your Monitor Resolution: in the market.
Additional Comments: going to be used mainly for gaming/Home theater PC. Looking for input on compatibility of the items i have researched a little. If they are completely incompatible, I'm a first timer and have very limited knowledge on this subject; which is why I'm challenging myself with this. Thank you all in advance for the time you are about to put into helping me. I appreciate it greatly.
The following are all NEWEGG item numbers. Please tell me if this sounds like a decent/compatible build:
Item # N82E16811129100 Antec 1200 tower-159.99
Item # N82E16822148681 Seagate Barracuda Green 2TB Hard drive- 119.99
Item # N82E16814127696 GeForce GTX 660 Ti 2GB video Card- 309.99
Item # N82e16829132007 asus xonar d1 7.1 channel sound card- 73.99
Item # N82E16817151098 Seasonic SS-560km active pfc f3 560W atx12v power supply 134.99
Item # N82E16813157296 ASRock Z77 Pro4 LGA 6Gb/s intel motherboard 109.99
Item # N82E16819115070 Intel Core i7-2600K sandy bridge 1155 95w processer 299.99
Item # N82E16827129067 Pioner bd/dvd/cd writer BDR 207DBKS 89.99
Item # N82E16820147134 Samsung 830 series MZ-7PC128D 128gb sata III SSD 121.99
Overclocking: Maybe
