So, sometimes my sound quality will go really bad or.. start just sound like gibberish. NJIOASDFSAFJSAF, hard to explain. :]
This has happened on my old computer and motherboard.
It's happening even on this new computer!
SPECS:
FX-8320
GTX 660
8GB RAM
128GB SSD/500GB HDD/1TB EXT
asrock 970 extreme 3
I'm starting to think, and maybe it's Virtual Audio Cable? I decided to disable it.. and still, every now and then it will just SKIP and sound crappy.
I found that when changing sound quality from 96000 to 48000 it fixes it.
Even when I leave it at 48k it still eventually goes bad, so I switch it to another and back.
I'm not sure if it started with USB headsets, but I don't use 3.5 anymore because they are just terrible.
The problem has occured on:
Tactic 3D Sigma
CM Storm Sirus
Corsair vengeance 1500
My vengeance broke, and my cm storm mic went out.
So I bought another Vengeance because cm storm sirus is discontinued.
Problem still exists...
Could it be something with my USB, and could I fix it?
Also, when it does that it does seem like my computer just randomly stutters/lags and things go into slow-mo mode. :[
Is it my proccesor? It's happened on:
amd phenom II x3 720
AMD FX 6100
and my current 8320.
There must be something behind it, and I'm hoping it's not virtual audio cable. (even though I did disable my lines through playback and recording devices to no avail)
SPECS:
FX-8320
GTX 660
8GB RAM
Tactic 3D Sigma
CM Storm Sirus
AMD FX 6100
