HELP *3001#12345# Help
Archived from groups: alt.cellular.nokia (More info?)
Please help
After I enter programming mode by keying *3001#12345#, what should I do
next. Their is no response and no NAM! menu should up.
thanks
5 answers Last reply
More about help 3001 12345 help
  1. Archived from groups: alt.cellular.nokia (More info?)
    On Fri, 03 Sep 2004 01:29:31 GMT, "nntp" <hesschu@rogers.com> wrote:
    >Please help
    How about a little more information such as what phone you are trying
    to program?
  2. Archived from groups: alt.cellular.nokia (More info?)
    Hi
    it is Nokia 8390!
    I followed the instruction you show me before (search 'change alpha tag' ).
    After I keyed in the program code as mentioned
    *3001#12345#,
    it just stay on the screen and no response at all. Where is the ENTER key
    like computer??? Is it the TALK key??
    Step 2 NAM screen did not show up!
    Please help
    thanks
    "Joseph" <JoeOfSeattle@yahoo.com> wrote in message
    news:0spfj0hrs2ncp96f3rucbp394oho9aslf9@4ax.com...
    > >Please help
    > to program?
  3. Archived from groups: alt.cellular.nokia (More info?)
    nntp wrote:
    > Hi
    > it is Nokia 8390!
    > tag' ). After I keyed in the program code as mentioned
    > *3001#12345#,
    > key like computer??? Is it the TALK key??
    > Please help
    > thanks
    >>> Please help
    >>> I do next. Their is no response and no NAM! menu should up.
    >> to program?
    Dear nntp,
    GSM phones, like the Nokia 8390, don't have NAM2. AMPS and ANSI-136 (TDMA)
    and IS-95a (CDMA) phones can.
    John C.
  4. Archived from groups: alt.cellular.nokia (More info?)
    On Fri, 03 Sep 2004 03:49:11 +0000, nntp wrote:
    > Hi
    > it is Nokia 8390!
    That's a GSM phone.
    > *3001#12345#,
    Problem solved: GSM phones do NOT have a 'NAM screen'.
    .....NEXT!!
    Michael Turner
    Email (ROT13)
    zvxr.gheare1963@ivetva.arg
  5. Archived from groups: alt.cellular.nokia (More info?)
    On Fri, 03 Sep 2004 03:49:11 GMT, "nntp" <hesschu@rogers.com> wrote:
    >Hi
    >it is Nokia 8390!
    That's not what you wrote when you sent your last message! You wrote
    8360!
    >*3001#12345#,
    That code is for CDMA and TDMA phones only. 8390 is a GSM phone. If
    you had specified that model in your original message you would have
    gotten the correct answer!
    GSM phones do not have a NAM!
    I'm not sure if I recall what you were trying to do in your original
    question, but if it was to change the "banner" you can do that by
    having a graphic sent to your phone from web sites which usually has a
    fee with it or you can transfer a graphic to your phone with a program
    such as Logomanager, Logoexpress or Oxygen Phone Manager using either
    your phone's IR or with a data cable. If that's not what you wanted
    to know send your question again. It makes a great deal of difference
    when you ask a question to specify the correct model number seeing as
    how the different technologies often do things differently.
Nokia Programming
