thee_prisoner said:
Part of the problem is that TVs aren't great at text, that is why we have computer monitors.
I disagree. Although there are differences between a "TV" and a "Monitor" they have nothing to do with how the text displays due to any hardware issues.
http://www.engadget.com/2007/01/19/ask-engadgethd-what-...
The blurry text is due to a setting somewhere, he just hasn't found it yet. A TV can be used as a monitor with perfect text, it just has to have the right input, the right settings on the TV, and the right settings on the video card. I have two TVs I use as a monitor, and they are indiscernable for my 3rd display, which is a "PC Monitor".
Here is ONE example of a solution when many complained of blurry text. I hope it works in this case:
Copied from a review on Amazon.com.
"Most Helpful Customer Reviews
384 of 397 people found the following review helpful
5.0 out of 5 stars GREAT PC MONITOR --- Please READ!!!, June 19, 2010
By Tech Junkie - See all my reviewsThis review is from: Samsung P2770HD 27-Inch 1920x1080 5ms 16.7M LCD HDTV Monitor (Electronics)
Ok, I'm one of those who always want to get a product that can be used for different purposes and Samsung P2770HD LCD TV sparked my interest. This review is for those who keep saying this is not a good PC monitor (I can tell you right now that you are WRONG). I bought this and hooked it up using HDMI. I was initially surprised the reviews are right. Text seemed blurry but I DID NOT GIVE UP because I saw tons of MENU adjustments so I played around with it. I'm telling you once you do this, you will love this monitor and get it over its 2770H (no TV tuner) brother or any other dedicated LCD monitor.
I repeat, this unit is perfect as a PC Monitor using HDMI cable!
*** Before you read on, I'm assuming you have connected this to your PC using HDMI cable and you have the LATEST video card drivers for your PC. Don't even bother with the SAMSUNG drivers yet. You don't need those at the moment. Set your resolution to 1920x1080 before starting (if your video card can support it, most does!)
Here's what you do: (and you can do this while you're PC is ON up so you can see the display change right before your eyes!)
1. Open MENU
2. Go to "Input"
3. Select "Edit Name" to open up the "Edit Name" sub menu.
4. Scroll down to "HDMI" and select it, (watch carefully)
5. Now assign "PC" or "DVI PC" to the HDMI setting and voila!!!
*** I'm not sure what this setting is for, I thought it was just to give it some "name" assignment. But somehow changing this corrected the blurry/blocky text effect.
After this, your PC display should be perfect. If text is still blurry, check if the display/resolution fills the entire screen. If not, this has to do with video card scaling option which can be easily adjusted from the video driver configuration. If you are using an ATI based video card, do these additional steps. (NVidia based video cards should also have an equivalent for this).
For WinXP
1. Open up Catalyst (video card configuration tool)
2. Go to DTV or DTV (DVI) menu on the left.
3. Select sub menu "Scaling Options" and set slider to "0%" towards "Overscan"
4. Done! PICTURE IS PERFECT!!!
For Windows7/Vista
2. Pull down Graphics menu
3. Select "Desktop & Displays"
4. Right click on the monitor icon at the bottom of the screen that appears.
5. Select "Configure..."
6. Change the scaling options same as the above.
Note: I'm not a MAC user so I don't know how the video configuration looks like for ATI in MAC. Probably any one of the 2 above.
Enjoy this monitor!
I can switch input sources PC/TV, turn the unit on and off and the picture is ALWAYS PERFECT.
For those who gave this unit poor reviews as a PC monitor, I'm sorry but you just gave up on one solid product that can be both a TV and a damn good PC monitor. Those who complained about dead pixels or backlight leaks (that is of course another story and you may have gotten a bad unit). Sound is reasonable for me. Just get a good external speaker (cheap) and you're done! You have 2 choices for audio out anyway (3.5mm and optical out). For it's price, this simply gives you more bang for the buck.
UPDATE: I noticed that for ATI video card drivers, installing the "driver only" will not show scaling option in the settings. I recommend downloading/installing the entire catalyst software to enable this option. Because I don't have any NVidia hardware at the moment, I'm not sure if NVidia's custom driver installation will have any effect on scaling options.
Also be mindful if you're using an external HDMI switch/box. Low quality HDMI switches may show some screen artifacts so be sure to test the monitor first using a direct HDMI connection, then return the HDMI switch after you've finalized your driver settings. "
