Tom's Hardware > Forum > Digital Camera > Digital Camera General > 350D and 580EX flash problem?
Forum Digital Camera : Digital Camera General - 350D and 580EX flash problem?
Archived from groups: rec.photo.digital (More info?)
Hi,
Took a picture in P-mode with the flash -> 1/60 s f5.6. Same f5.6 in Av
mode yields 1/6 s shutter speed. What's going on? Am I missing something?
Arttu
Sponsored Links
In Av and Tv modes, the camera meters and sets the exposure normally both
when the flash is up and when it's down. When up, the flash is used to fill
in the shadows. This is the normal, correct, and desired behavior<g>.
David J. Littleboy
Tokyo, Japan
Reply to Anonymous
So there is no way to benefit from increased sharpness with smaller
apertures (of eg. the kit lens) in flash photography? (exposure times get
too long for handheld operation)
Arttu
"David J. Littleboy" <davidjl@gol.com> wrote in message
news:dfrbio$hu7$1@nnrp.gol.com...
> fill in the shadows. This is the normal, correct, and desired behavior<g>.
> David J. Littleboy
> Tokyo, Japan
Reply to Anonymous
Of course possible in M mode, but I meant in Av.
Arttu
"Arttu" <no.email@this.time> wrote in message
news:SobUe.9086$_k2.143598@news2.nokia.com...
> Arttu
>>> something?
>> behavior<g>.
>> David J. Littleboy
>> Tokyo, Japan
Reply to Anonymous
Just shoot in "M" mode and set whatever shutter speed/f stop combination you
like (as long as the flash has enough zorch). That's what people did for the
first 100 years of photography...
"M" mode is the correct mode for what you want to do.
The 350D's behavior in Av mode is normal, correct, and desired. It's the way
most automagic cameras have worked in the last few years. When you set the
camera to Av mode, that means "Hey camera, please set the shutter speed
according to the ambient light", so it does. With flash, this means "fill
flash mode". If you don't want the camera to set the correct shutter speed
for fill flash mode photography, then you have to do something different.
(Sorry to sound like a grumpy rant here: I'm just trying to explain what
"Av" means, and point out that what the camera does actually makes sense.)
David J. Littleboy
Tokyo, Japan
Reply to Anonymous
Arttu wrote:
> Hi,
David Littleboy answered your question, but if you're interested
in Canon's flash modes:
http://photonotes.org/articles/eos [...] #confusion
Reply to Anonymous
Arttu wrote:
> Hi,
> Arttu
Custom function 3 can be used to force a 1/200 s flash sync in Av mode.
John Reagan
Reply to Anonymous
> Arttu
I've had some success using the high speed setting on the gun. Set H on, use
about 1/500s and dial whatever apeture you fancy. If the flash can put out
enough light the histogram will be normal (on the info screen). If you've
been a bit optomistic with the apeture then the peak will be shifted to the
left. Then dial in some extra ambient by dropping the shutter speed or open
up the apeture bit by bit until the histogram shows all is well.
John
Reply to Anonymous
Any URL ending in "confusion" _has_ to be good! I'm off to read. ;)
http://08016.com/ - Burlington City history on the internet, since 1995.
Reply to Anonymous
There are 1151 identified and unidentified users. To see the list of identified users, Click here.
Sponsored links
