Approximate Purchase Date: This Week to next week.
Budget Range: Under 400 if at all possible (as there is no need for a graphics card), but it is probably not.
System Usage from Most to Least Important: Gaming, video, programming (I am not very good so that requires nothing)
Are you buying a monitor: No, have 2 already.
Parts to Upgrade: The whole tower but my Nvidia GTX 560 Ti, which is doing pretty well.
Do you need to buy OS: Yes / No
No, luckily I have a full and expensive version of Win7 Pro
Preferred Website(s) for Parts: Amazon (I have prime) or New Egg (Good experiences)
Parts Preferences: Intel
Overclocking: Maybe, I have done it before, but I would need to be sure about cooling/saftey
SLI or Crossfire: No, budget issues.
Your Monitor Resolution: 1680x1050
Additional Comments: As you can see I don't need to pick up a graphics card, so I am hoping this will bring the price down quite a bit. I do not care about noise, but I want to make sure that is it stable, cooled and powered right. I also need a wireless card, as I can't run wires to where my pc is.
And Most Importantly, Why Are You Upgrading: I am running on an intel core 2 duo atm, which was a very good chip, but is getting far too slow. But if I upgrade the chip, I need to upgrade my motherboard, my power supply, ect, ect.
Thank you for any responses, I don't have the brain power to dedicate to learning how to put something like this together right now, so it would be doing me a big favor.
