I Purchased all the parts last Saturday from a memory express store (August 18th i believe).
Parts List is as follows;
Case
Cooler Master HAF 922
Power Supply
Corsair TX850
MotherBoard
Asus p8z68-v/Gen3
CPU
i7-3770k. 3.5ghz/8mb
RAM (2x 4GB)
Corsair Vengence 8gb DDR3 1600MHz Dual Channel.
Graphics Card
EVGA GeForce 660ti 2GB GDDR5
Hard Drives
HyperX 3K series SATA 3 SSD
Seagate 1TB Barracuda
I did not overclock anything.
So i bought it got it all together, hooked up to a monitor and nothing, there is no output. I know the monitor works ive used it before, i also tried it on another monitor just to be sure and the same thing happened.
everything seems to power up fine, no errors, no beeps, nothing.
I have done and checked and rechecked just about everything i can think of but im kinda burnt out maybe someone here will have a suggestion that hasnt crossed my mind.
I have tested everything, the motherboard has error leds and everything comes up fine acording to the MOBO so idk maybe its the motherboard itself?
Memory express has a policy where if they don't install the RAM and CPU themselves then it voids there store warranties so i let them install those and i checked them and they seem fine, again no error LEDs.
I tested the RAM, i took it all out and tried one at a time and ive tried them in differnt slots and it had no effect.
I tried running the video initially out of the GTX with same result i then switched the monitor to the motherboard onboard video to try and make it simpler for trouble shooting.
like i said Pretty much everything.
I would appreciate any help.
Thanks.
Case
Power Supply
Corsair TX850
MotherBoard
Asus p8z68-v/Gen3
CPU
RAM (2x 4GB)
Graphics Card
Hard Drives
Thanks.
