Solved
CPU Fan Speed
Hey, I recently upgraded my computer. I switched cases, added a new psu and a new video card. When I booted the computer the bios said to reset the time again so I did. After I hit save the fan speed jolted up to 100% and now it is stuck there. I looked all over the bios for a setting but its seemed to be locked because its a acer locked motherboard. I tried speed fan but that didnt work either. I know I can control the speed because the fan has 4 pins. Any help?
3 answers Last reply Best Answer
More about speed
  1. Best answer
    Pull out the CMOS battery and replace it with the same type. You can find those batteries in any supermarket or drug store. That will reset the BIOS and should solve your clock /date problem.
  2. Best answer selected by kkty5.
  3. Have you had a chance to test what I said above? If so did it work?
CPUs Computers
